here you go, the blue circles are screws that are behind the cup holder, the purple circles are tabs that just need to be pulled to remove, and the yellow cirle is the hazard connector. first unscrew the cupholder and remove it, pull out the upper vent area disconnect the hazard switch, and pull of the HVAC trim both of the last 2 just pull off and can take a bit of effort
LinkBack URL
About LinkBacks
. if anyone has any advise i would really apriciate it. thanks in advance
