Results 1 to 3 of 3
This is a discussion on aftermarket radio install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; maybe someone here knows the answer to this. when you install a single din head unit in a 07 wrx ...
    Registered User climbnsparky's Avatar
    Jan 2007
    PDX
    maybe someone here knows the answer to this. when you install a single din head unit in a 07 wrx waggon do you need a bracket kit?? the car came with the 6 disc changer (double din). i have asked at a few of the shops in town and i am having a hard time getting a straight answer.
    also what are you guys doing with the extra space left in the dash? is there some kind of insert to cover up the hole?
    thanks
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by climbnsparky View Post
    thanks
    Dont think you do, as the brackets come off of the stock HU and bolt onto the aftermarket HU. I just threw the squirll cage away.
    You will need something to take up the xtra space though. You can order a forester pocket (has flap door) or the WRX TR pocket (no door)
    Registered User Robman7835's Avatar
    Jan 2006
    York PA
    Double Din FTW!!......my unit used the stock HU mounting brackets............
    PSM Bugeye..Cobb Stage 2
