Results 1 to 7 of 7
This is a discussion on Prosport electronic boost question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I installed my gauges and took it to a shop to have the EGT gauge done. When they hooked it ...
    Sep 2005
    Salt Lake
    I installed my gauges and took it to a shop to have the EGT gauge done. When they hooked it up, they took it out for a drive and told me my boost gauge was acting weird. They said it was reacting very slowly and did not seem to be reading totally accurately. The needle doesnt move very quickly and it doesnt even get to "0" until after i can tell the boost has kicked in. We hooked up mechanical gauge they had at the shop and everything worked fine. It either has to be the gauge or the only other thing i could think of is maybe its a side effect from the gauge being electronic. anyone have any experience or insites perhaps?
    Registered User John_M's Avatar
    Sep 2006
    Phoenix
    so is your gauge showing boost or is it just moving around in vac?? the gauge being eletrical should not be an issue
    2006 OBP WRX
    HAWK-EYE Alliance#072
    Sep 2005
    Salt Lake
    If i really get on the car it will eventually get up to about 13 psi which seem a little less than it should be. So no, its not just in vacuum
    Sep 2005
    Salt Lake
    Bump in hopes of a reply
    Registered User kpSTi's Avatar
    Los Angeles
    It should be reading almost 15 psi at full boost (14.5psi). I have the prosport boost Gauge and it spends most of its time in vacuum(Unless you get on it and spool the turbo all the way up). Mine was reading low also when I put it in. One of the vacuum lines wasn't on all the way. Check them real good. Make sure there are no kinks in the line.
    '08 WRX SSM
    Mods:
    Engine- COBB AP, stage 2 Perrin map and intake, SPT CB exhaust and Invidia catted DP.
    Suspension- SSR Type-F 18x8 +45 offset, Rallitek F/R swaybars and HD endlinks, H&R springs, camber bolts and Cusco front strut tower bar.
    Exterior/Interior- '09 WRX grill, Factory Front lip, Fog lights, STi 5 speed shift knob, Armrest extension, painted rear chrome strip and debadged trunk.
    Sep 2005
    Salt Lake
    Does it still ready slow after checking the hoses? As for mine, like i said before, we hooked it up to another boost gauge which read with no problem! So i dont think its the line. We also tried hooking up a seperate tube to make sure.
    Sep 2006
    Phoenix
    i would call prosport and talk to them, the gauge shouldnt be reading slow. especially since you tried a different gauge and it all worked fine. get prosport to sway the gauge out.
    2006 OBP WRX
