This is a discussion on vacuum line for boost gauge within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; so wheres is the best place to hook the hose up to for an 06 WRX ? wow you have ...
wow you have to remove the intercooler just to get a vacuum hose?
the WRXtra instructions say to remove the intercooler and set it aside..
I "T"d off of the BOV vacume line and I feel I get very accurate readings. I tried going off the wastegate solenoid vac. line and got no reading. You can also use the vacume line on the intake manifold like showed earlier and that would also be accurate.
The most accurate readings come from here:
