air/fuel gauge hook up
Results 1 to 8 of 8
This is a discussion on air/fuel gauge hook up within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i am getting an air/fuel gauge and i wanted to see if anyone else has one and if you hooked ...
    Registered User gsxrmcs's Avatar
    Jun 2006
    i am getting an air/fuel gauge and i wanted to see if anyone else has one and if you hooked it up where do i hook up the signal wire to so that i get the correct reading. if anyone has any answers please let me know
    thanks
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Hooking it into your stock narrowband will make it next to useless, get a wideband and hook it into that.
    Jun 2006
    ok but if i want to hook it up for now what wire do i tap in to
    Oct 2003
    Way up high.
    Quote Originally Posted by gsxrmcs View Post
    well if you're doing it just for show you could get a scrolling led or tap it into the wiring for your stock narrowband.
    Jun 2006
    well for right now it is going to be for show. do you know what wire it is that i should hook up to
    Oct 2003
    Way up high.
    nope
    Registered User vypr2002's Avatar
    Jan 2006
    hey brian, If I have a AFR gauge already and its taped to my narrowband stock setup. what would I need to get a wideband setup using my existing afr?
    or is it possible.
    gsx--just tap it to your o2 sensor I think its a blue or green wire. just do a search. there is tons of info. also look in the diy section. and tutorial section
    WRB 06 TR wrx wing, wrx foglights, Invidia catted downpipe, AP,
    Stage 2 map, SPT catback, STi oem springs, Katrboy shortshifter
    lots of audio gear too.
    Oct 2003
    Way up high.
    Well, you'd have to make sure that whatever gauge you get will work with whatever aftermarket wideband you purchase. But yeah you'll have to get an aftermarket wideband.
