aftermarket stereo dimming?
Results 1 to 3 of 3
This is a discussion on aftermarket stereo dimming? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Anyone with an aftermarket stereo figure out a way to use the dimmer for the interior lights to trigger the ...
    Oct 2002
    Underground Particle Accelerator
    Anyone with an aftermarket stereo figure out a way to use the dimmer for the interior lights to trigger the stereo dimming? Our cars (02's anyway) use an a$$-backwards dimming system. Most cars dim lights by reducing the voltage from 12V down to ground on the illumination wire. The WRX supplies 12V on one of two wires in the illumination circuit and brings the ground up to 12V on the other wire.
    Registered User kiger0183's Avatar
    Oct 2005
    SLC, Ut
    I installed an after-market alpine deck in my 05 wrx with auto dimming feature with no problems. I know on the 05 i believe it's the yellow wire (usually NOT in the aftermarket bracket) You actually have to hot wire it directly to the stock wires if that makes sense.
    Stage II and loving it!
    Oct 2002
    Subaru changed the 04-05 then. Turns out I found what I was looking for on ScoobyMods:
    http://www.scoobymods.com/forums/showthread.php?t=3115
