Results 1 to 8 of 8
This is a discussion on '07 TR Pedal Kits???? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Anyone know of an aluminum pedal kit for the '06 or '07 TR? sgp.com says that their kit won't work ...
    Registered User trpalmer101's Avatar
    Nov 2006
    Anyone know of an aluminum pedal kit for the '06 or '07 TR? sgp.com says that their kit won't work with "wire throttle" 06 TRs.
    Apr 2006
    St. Augustine, FL
    im intersted as well for my 06 TR...........
    Sep 2005
    Los Angeles, CA
    uummmm pedals are pedals, aren't they? I mean, DBW or not, your foot still pushes something. And since the car comes with pedals, replacing them changes nothing. I have a set of aluminium pedals from Pep Boys, and i've had no problems at all. Just make sure that during the install, the actual piece that your mounting the new pedal to has its full range of motion.
    "You may say the grill is ugly...but thats ok...you wont see it when your behind me"
    Hawk-Eye alliance #004
    Apr 2006
    St. Augustine, FL
    I think the both of us are looking for oem style alum pedals........
    Nov 2006
    Idok hit the point. Also, if function was all we cared about in this world, then it'd be one ugly world to live in. Then again aesthetics are functional, just depends on your perspective.
    Apr 2006
    St. Augustine, FL
    you know, now that I think about it....
    that kit might work on an 06....seem to remembre reading a writeup on scoobymods where they put one of those on a TR...
    could be wrong though....
    Moderator
    Jul 2003
    Maryland
    My 06 LTD comes with alum. pedals..might want to try OEM.
    Registered User jtodaro's Avatar
    Sep 2006
    Quote Originally Posted by 302@12psi View Post
    06 WRX TR uses the same gas pedal assembly 2.5RS which is is not the same as the LTD/STI models. The Brake & Clutch pedals will interchange. To switch out the gas pedal assembly to the LTD/STI unit, will run you about $150 from Subaru. Alternatively, there is a writeup that tells you how to modify your gas pedal assembly and make it work without thie new unit from Subaru.
    http://http://forums.nasioc.com/foru...ghlight=Pedals
    jt
