Other than Boost What other Guages needles move
Results 1 to 15 of 19
This is a discussion on Other than Boost What other Guages needles move within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Other than the boost guage, what other guages are there that have frequent movement? A/F and Boost I know oil ...
    Aug 2003
    Philadelphia, PA
    I know oil pressure is good to know as well as oil temp but what other guages have alot of movement during driving?
    Thanks in advance
    Rudy
    Power is nothing without control
    Registered User Robman7835's Avatar
    Jan 2006
    York PA
    Speedometer..... Tachometer..... Odometer....
    PSM Bugeye..Cobb Stage 2
    Oct 2004
    Westchester Cnty, NY
    All you need is Boost and an EGT if you are modded. The EGT doesnt move much since it measures temperature.
    I realize you want to show off to friends while driving, but you might as well just get an in-dash display to show movies at that point.
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    oil pressure moves around a little, I like it, because you can tell when your oil is up to operating temp. It will sit constant at about 85psi when you are driving, and it will drop to about 25psi when at idle.
    Aug 2003
    Philadelphia, PA
    Robman - don't quit your day job
    Downshift - good point and well friends or not personally I like the entertainment value as well, friends are simply amazed that they arrived at the destination alive.
    afbluesv1k - I figured that the oil pressure would move, how about fuel? I think that would just stay stable once the motor turns over or once the ignition is engaged
    anyone else? So far it’s EGT, Oil Pressure and what else? Need one more
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    you could do a coolant temp to watch overheating
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    May 2005
    Phillytown, PA
    Quote Originally Posted by afbluesv1k View Post
    How does an oil press. gauge tell you your oil temp?
    Quote Originally Posted by bkotzman00 View Post
    A WRX has a coolant temp gauge stock.
    Apr 2006
    York, PA
    true on the coolent temp but if he is going for looks why not one that reads in degrees instead of 1/3 the way from the bottom
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    May 2005
    Phillytown, PA
    I guess if the goal is simply to buy a gauge that moves. I that case, maybe mount the temp. probe in the center of the driver's seat and then you would know if you have a fever coming on.
    Registered User wizzman's Avatar
    Mar 2005
    Andover, MA
    ricer
    Administrator
    May 2003
    Oct 2005
    Late Devonian
    Quote Originally Posted by wrx wagone View Post
    Apr 2006
    York, PA
    that would be more useful than an air/fuel gauge hooked up to the stock o2 sensor
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Jan 2006
    York PA
    Quote Originally Posted by Deznuts05 View Post
    Your the one that asked what needles move while driving......
    Jan 2006
    York PA
    Quote Originally Posted by Trainrex View Post
    .....i love the fine print at the bottom
