Tachometer installation??
Results 1 to 5 of 5
This is a discussion on Tachometer installation?? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Where is our: 1. Ignition coil, or Tach feed 2. access to the ignition switch Thanks, Dave...
    HERSHEY, PA
    Question Tachometer installation??
    Where is our:
    Thanks,
    Dave
    Registered User djrez4's Avatar
    Colorado
    Engine speed wire should be tapped off of the ECU. Ravensblade WRX has the ECU pinouts on their website, here
    The ignition is accessed under the driver's side dash. It's the set of blue plugs down there. Look up a turbo timer installation, as it involves both of the wires you're asking about. Here are some pics of a turbo timer install involving the ignition harness.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    HERSHEY, PA
    How do I get to the ECU?
    Colorado
    It's under the passenger side footwell. Take out the floormat and pull up the carpet.
    Registered User Root's Avatar
    May 2001
    Sacramento, CA
    My WRX came with a tach in the dash next to speedo, didn't yours?
    Good judgement comes from experience,
    and experience comes from bad judgement.
