what amp (dimesnsions)? ported or sealed enclosure? the only way to clean up the sound of a solobaric is to dynamat the crap out of anything and everything. peel-n-seal from the local hardware superstore when used in multiple layers does the same thing, except cheaper. i have a ported solobaric L7 box. it eats up the entire dent between the wheels and i don't know if a strut bar will fit above it. this will hopefully keep the majority of the weight over the axle. i plan on putting my sub amp on a steel rack and suspending it so it hangs out over the front of the box slightly. my amp for the my door speakers will hopefully still fit (on tilt) in front of the box. this will effectively destroy any storage capacity my trunk hadOriginally Posted by karis119
, but i want loud music more than trunk space. good luck and post pics when you are done
LinkBack URL
About LinkBacks
