Results 1 to 5 of 5
This is a discussion on do-it-myself audio upgrade...help!!!! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; so i have two subs and an amp, made my custom box so it all fits nicely in the trunk.... ...
    Registered User bwhere's Avatar
    May 2006
    Houston, TX
    so i have two subs and an amp, made my custom box so it all fits nicely in the trunk.... now im getting ready to actually install everything and had some questions- what exactly do i need to hook everything up to my stock head unit? anything special?
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    A line level adapter. You'll need to splice it in/sauder (sp?) a line level adapter to your rear spearkers, that will give you the RCA output or whatever you'll need. I think I got one for $30 or something at Quality Auto Sound. Probably way cheaper on Ebay. But that should work to wire in subs and amps.
    PM me if you have questions. Other than a new HU, there's no way to do this unless your amp has a speaker wire input thingy.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Registered User kevlarcupid's Avatar
    Dec 2005
    Baltimore
    Quote Originally Posted by Thug Nasty
    sauder (sp?)
    solder
    In short: HLGBGUAHUGLABLAGUHGALGHAGHL
    Mods::Pics
    Jul 2006
    Quote Originally Posted by kevlarcupid
    solder
    Thanks cutie
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Connecticut
    you dont need solder actually, just use side terminals or cut the wire and then... solder and heatwrap (prolly best bet)
    make sure you get shielded wires, although they dont make the audio invincible from getting noise.. it does reduce noise alot!
    also, you many need the pinout for the radio..
    http://www.geocities.com/svxdc/WRX-pinout.htm
    else you wont know which wires to connect
    2004 Subaru Impreza WRX CarPC Install
    MP3 - VIDEO - DVD - FM Radio - XM Radio - WiFI - Bluetooth - GPS - NES, SNES, SEGA, PS1, GBA Emulators & Games
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
