i had a air/fuel hooked to the factory o2 sensor and it was just a dancing needle, but there are more than one write up on the site
This is a discussion on RE:O2 Sensor within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi everyon, im new here and i recently purchased a 06 wrx turbo and i was wondering if anyone can ...
Hi everyon, im new here and i recently purchased a 06 wrx turbo and i was wondering if anyone can tell me what wire from the ecu is the signal wire so i can connect an A/F gauge. Any help would be appreciated.
04 WRX Java Black
Mustang Dyno 218 awhp 216 awtq
1978 Honda CB400Tll
yea you know its modified![]()
1974 Honda CB750 Bobber
still in the works
Where?? I hooked up a Apexi turbo timer and its equpipped withe A/F and o2 signal readings and i have to hook it up to the signal wire i just dont know which one it is
i think it is B17 on the ECU, i don't have a wiring diagram handy for you though
04 WRX Java Black
1978 Honda CB400Tll
still in the works
Ill try that pin to see if it works. B17, from which connector is it from looking at the ECU, Cause there is four different ones
Ill try that pin to see if it works. B17, from which connector is it from looking at the ECU, Cause there is four different ones And do u know what color the wire is by any chance?
here found this with about 5 minutes of looking around
Autometer dual A pillar and grounding kit installed tonight
04 WRX Java Black
1978 Honda CB400Tll
still in the works
