Kartboy STS in 06
Results 1 to 7 of 7
This is a discussion on Kartboy STS in 06 within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Okay .. so I'm installing right now. Can't seem to get the ball end of Kartboy to seat in the ...
    Registered User esco301's Avatar
    Jun 2006
    Southington, CT
    Kartboy STS in 06
    Okay .. so I'm installing right now. Can't seem to get the ball end of Kartboy to seat in the housing. Any suggestions?
    Drive, monkey, drive!
    New England F4
    Registered User WRX88's Avatar
    Dec 2005
    New Jersey
    Hold the shifter as low as you can and keep it steady. Try and find and angle (I think i tilted it towards me) and wack it as hard as you can.
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    use a deadblow hammer of some sort. so you dont destroy the threads. i learned the hard way. but thats all you gotta do hit it with all your might
    you can also use a regular hammer with a block of wood over the SS and hit the wood.
    2006 Aspen White STi
    Stage 2 Open Source Road Tune
    A bunch of bushings from TiC
    Feb 2005
    md
    hold the shifter at the same angle that you pulled the stock one out and hit it with a rubber mallet it should pop right in. that's what I did.
    Registered User kevlarcupid's Avatar
    Dec 2005
    Baltimore
    I've heard that covering the top of the SS witha phonebook, then hitting the phonebook with a mallett helps a lot. You've really gotta hit it, though. Like I do with women.
    In short: HLGBGUAHUGLABLAGUHGALGHAGHL
    Mods::Pics
    Dec 2005
    New Jersey
    Quote Originally Posted by kevlarcupid
    +1
    When they get stubborn. you just gotta wack 'em a few times
    The short shifter, that is.
    Registered User Cathode's Avatar
    Aug 2006
    Westchester Co., NY
    This was much tougher than I anticipated it to be. After trying everything else I ended up using a mini sledgehammer and just about all of my might. THWAP!
    Just give it a real good wack and she'll pop in there.
    Oh, and then I realized that the Kartboy SS does not fit with the Subaru short shifter linkage in!
    So I had to take it back out and trim about 1/8" off each end of the shifter with a dremel/hacksaw/grinder bit and then wack it back in again. But it works now.
    BTW, if you didn't install the bushings as well get them, and do it. They made a noticeable difference in shifter feel. Overall I'm very happy with this mod.
    Cobb Stage 2 '06 WRX, Aspen White & Wingless
    Hawk-Eye Alliance #026
