Lamco Boost gauge question
Results 1 to 6 of 6
This is a discussion on Lamco Boost gauge question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have the stock boost gauge on my car right now and I know that it is very very innacurate. ...
    May 2006
    Near Gettysburg PA
    I have the stock boost gauge on my car right now and I know that it is very very innacurate. I want to buy a different gauge and intall it in the same spot. Can I ust the same T fitting, wires and all. What type of gauge is the stock one?
    Oct 2004
    Westchester Cnty, NY
    The stock Lamco isnt that inaccurate. In fact mine is nearly perfect.
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    May 2006
    Near Gettysburg PA
    no mine is way off. It reads vaccum when the car is off. And if it was correct the most boost I would ever see would be .05. It never goes above that. Even 3rd gear WOT
    Oct 2004
    Quote Originally Posted by Rappy04
    Sounds like you have a problem with the install not the gauge. You should be seeing about .09 MPa in 3rd at WOT. and the gauge should read 0 when off.
    See if the dealership will fix it since its a factory option.
    Im pretty sure the stock Boost gauge is Mechanical.
    May 2006
    Near Gettysburg PA
    I bought the car used so I doubt that the dealer will fix it for me. Will I be able to just switch out the guages and not have to run new wires and such?
    Registered User brujito's Avatar
    Nov 2005
    Brisbane
    the wires on the gauge are directly connected to the gauge so you will have to cut and solder it back on to the other gauges wires but yeah you can use them they are all the same
