Where to buy carbon fiber?
Results 1 to 7 of 7
This is a discussion on Where to buy carbon fiber? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; hi all! im looking for a piece of CF to use as the mounting plate for my custom gauge project. ...
    Jun 2006
    Cambridge, MA
    hi all!
    im using a OEM subaru guage pod(the clock delete one). it doesnt come with anyway to ount the gauges jsut a square hole. id like to cut CF to fit the hole and 3 55mm gauges. does anyone know where i could the the materials to do this or even better a place that could do it for me for a good price???
    Jul 2006
    Mcmaster carr sells finished carbon fiber sheets. A 12" square piece will run you $30-$50.
    Jun 2006
    Cambridge, MA
    thanks! what an awsome website! http://www.mcmaster.com/
    12x12 x1/32 for 33 bucks....is this thick enough for my use???
    does anyone know they best way to cut CF for a clean look?
    Jul 2006
    Use carbide or diamond tools. If you don't have those, use a dremel cutoff wheel (the black fiber ones, not the cheap red sand like ones that shatter). We made the RIT F1 racer body out of carbon fiber and actually used scissors to trim the edges, but we were starting with cloth and putting the resin on ourselves so the fringes were easy to cut. We then use a dremel and a steady hand to get the edges close, and then sanded...a lot.
    Your best best is to find a way to mount the CF so that the edges are hidden behind something so you can't see them.
    Registered User lukeskywrx's Avatar
    Apr 2004
    Rolla, MO for school/STL
    thin sheets of cured cloth should be treated like brittle plastic. if you are too rough with it its gonna chip or pull apart, just test your cutting tool on the scrap side first to see if it works with CF.
    luke
    I just don't get this drifting thing, why would I spend money to put a car in the wall for a bunch of stupid 16 year olds with dreams of fast and Furious?
    Grip or Die!
    Blobeye Syndicate #17
    Jun 2006
    Cambridge, MA
    Thanks guys!
    i do have the black cut-off wheels for the dremel. i am more concerned about cutting the holes for the gauges.......im assuming a carbide drill bit will work? im not sure if ill have access to them. i need to cut three holes for 52mm gauges in a small rectangular peice that is going to fit into the factory clock delete betzel
    Apr 2004
    your kinda missing the point, carbon fiber is not hard and it is really weak in shear. a hole saw will do the job if you go slow and dont push. you dont need carbide tools, they just need to be really sharp to reduce the fray. I have found dremels and CF to be a bad mix because of the fray and it is so hard to hold it steady on the slick surface.
    sharp wood working tools and patience will give the best results, I always cut anything i could with a big arm paper cutter because it chopped so clean.
    buy some extra and play with it first, you will see it is really easy to work with, like hard wood with no grains or flaws.
    and i want pictures
    luke
    Grip or Die!
