How can this be!!!!
Results 1 to 5 of 5
This is a discussion on How can this be!!!! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was installing my amp and subs I did NOT have the power hooked to the battary. I had the ...
    Registered User seth7685's Avatar
    Aug 2005
    AL
    How can this be!!!!
    I was installing my amp and subs I did NOT have the power hooked to the battary. I had the amp mounted and hooked up, but wanted to run the power and ground wire differently, so i went to take the power off (stupied to do that first anyways) and there were so small sparks when i touched the screw driver to the + amp termal. I thought that was wierd but i figured it was just static so i did it again and the same that so i was like .
    Then i put my DVOM to it and guess what i found.
    1.129v from a amp that has been seating inside for 3 months any type of cap. inside the amp should have loss it energy by now. I'm confused someone help me out.
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    I'm not sure what you're asking, but reading voltage across two points like that isn't too interesting. Voltage =/= power. I hope your stuff ends up working.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    was your remote wire ever hooked up? if so then it could have saved up some juice...
    07 white STi in CT
    Aug 2005
    AL
    Quote Originally Posted by ryanwrxduksa
    no i haven't put power to it yet in any way i just checked it again after its been seating in the floor like the picture and its up to 1.288v
    Aug 2005
    AL
    amp is toast anyone know where i can get another one really quick for not to much $ ?
