AC outlets where ashtray used to be
Results 1 to 4 of 4
This is a discussion on AC outlets where ashtray used to be within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Right now I'm installing 2 AC outlets and a 200W power inverter where the ash tray used to be. I'm ...
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    Right now I'm installing 2 AC outlets and a 200W power inverter where the ash tray used to be. I'm thinking I'm just going to wire the +12V and the ground directly into the wires coming from the cig lighter I'll use thicker wires if need be. Any comments or advice, post away. Pics will be up when I'm done.
    Registered User eld4au6's Avatar
    Dec 2005
    Anniston AL
    off topic: sweet you live near me: off topic
    good luck,yeah you should probably use bigger wire
    -05 CGM STiBlobeye Syndicate #4
    -97 Acura SLX totaled 231k
    -95 Toyota Land Cruiser
    Feb 2006
    Kentucky
    More than likely, the 200w inverter is going to pull more current than the factory wires can handle. I would recommend running heavier gauge wires. Attach the 12 volt wire to the heavy gauge acc. wire in your ignition harness and ground it to a factory bolt or make a new ground to bare metal.
    Jun 2006
    the ham
    thanks for the tips. This inverter was designed to run out of a cig lighter, which is why i was considering just tapping in, but if i want to still use the cig lighter for anything, i bet i will need lower gauge. the inverter is a near perfect fit in the ashtray cubbie once i took out the rails.
