Seat noises
Results 1 to 6 of 6
This is a discussion on Seat noises within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have been having an annoying squeeking in my seat everytime the turbo kicks in and my heinie flies back, ...
    Registered User Twanz02WRX's Avatar
    Nov 2002
    Kansas City, MO STL,MO Originally
    Exclamation Seat noises
    I have been having an annoying squeeking in my seat everytime the turbo kicks in and my heinie flies back, (it happens very often ). I am probably one of the bigger WRX pilots at about 6'1'' and 250lbs. It has gotten to the point that it affects the way I drive, now I am trying to "ease" into every gear to avoid the sound. I have put WD 40 on the left and right sides of the seat hardware with little to no success. What else can be done to silence this?
    "You have to let it all go; fear, doubt, and disbelief. Free...your mind."
    You can run, but between my Glock and My WRX- you will only die tired.
    2002 Black WRX Sedan RIP 08.24.04
    2005 Black WRX STi 09.14.04
    Registered User Dizzy's Avatar
    Lafayette, CO
    Question
    Man, that's weird. Mine just started doing that, too. I don't think it's size dependant. I'm 5' 9", 170lbs. It is REALLY starting to bug me.
    Registered User PKer's Avatar
    at work
    I think it's probably the seat belt. I was getting it too; I hooked the belt up then gave it a good yank to kind of stretch it it has worked for now.
    Nov 2002
    The seat belt eh? I will try the pulling method. I am driving from Kansas City to St. Louis and I want to take the Subie if I can stand that cursed noise otherwise its the wife's 94 Camry= no fun/long drive.
    Thanks for the replies, I'll let you know if it works.
    AJ
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    Its the seatbelt alright. The yanking method gets rid of the noise for about 5 minutes in my car and then it comes back. It drives me SO crazy. I usually have the radio on so I don't hear it, but sometimes I like to listen to the engine and not the radio and then I hear it all the time My passengers get a good show when I flip out and yank the hell out the seatbelt in some way shape or form. I wish I could get rid of it permanantly. If anyone has any success, please post it.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    Nov 2002
    Try to tighten the bolts that bolt the seat rails into the the floorboard. I tightened mine yesterday, and noticed a BIG difference. There are still some subtle noises from the seat back. But this helps a lot. I believe all of my weight flying backwards for 13,000 miles (from my enthusiast take-offs) has loosened the screws. My previous car was a Corolla. This was not a problem. Please post your outcome(s).
    aj
