How to not get jacked!
Page 1 of 5 12345 LastLast
Results 1 to 15 of 65
This is a discussion on How to not get jacked! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; • ALWAYS use common sense. Don't 'bump' where you live, esp. if you live in an apartment • If at ...
    Jun 2002
    • If at all possible, avoid putting any stickers on your car (be it performance or audio) they just scream "steal me! steal me!"
    • If you go to car shows/soundoffs, I suggest removing your license plate temporarily. This will at least make it hard for people to remember your car is packing what gear(s)
    • Consider getting dark limo tint and car cover. Remember - out of sight, out of mind.
    • when you go to a mall or a store, turn down your system at least 2 miles BEFORE you get there. When a thief hears you bumpin down the road, he will follow you till you park and jack your equipment when you leave. Anybody who's desperate for money will do ANYTHING to steal something.
    • Please Please Please install an alarm. I know about 30 people who pack thousands of dollars worth of competition-grade Audio Equipments in their SPL vehicles and they don't even have a $100 car alarm How stupid can you be..
    • 'modify' your car alarm.. It might be an overkill, but I'll install 10 additional siren around the car - two inside the hood, two underneath beside the cat, two in the trunk, and four in the cabin. Thieves don't have enough time to cut all those wires while they're blaring 130bD.
    • I betcha right now I can guess where you all have your alarm brains.. they're under the dash. right? that thing can be disabled in less than 5 seconds! Don't be a fool, move that brain somewhere hidden. Mine has mixed wire colors and false wires all around, Not even a professional installer can unload it.
    • modify your Kickpanels to hide the hood release latch under the dash. Mine is covering the whole thing so you will have to reach inside the kicks to pop the hood. One time I took it in for an oil change it took the guy about 10 minutes to figure out where the hood release is This is extremely important so that the thief can't disconnect your +12 source and disable your alarm.
    • I can't emphasize enough how extremely important security screws are. These are oddly-shaped head screws that you can get from any hardware store. Nearly ALL thieves carry a flat screwdriver and/or phillips screwdriver all the time. A hex or square head screw will definately slow them down. If your amp is bolted to the amp rack like this, there's NO WAY they can take your equipment.. but make sure your amp rack is bolted as well.
    • Ask your insurance provider if they can cover your equipment.
    • Be careful on who you show your system to... remember that every person is a possible thief. Even people who post here.
    • Don't leave anything "interesting" inside your car (cellphone, jewelry, heck even a quarter) this will only attract passerbys that can possibly lead to theft.
    • make sure all your fuses are good and have the right rating. Moreover, make sure your equipments are FUSED. In worst case scenario, after an equipment is stolen, wirings short out literally putting the car on fire.
    The next time you roll down the parking lot, remember to keep them bass down cause having a system is like having sex--- you'll never know when you're gonna get jacked
    Additional Tip: For those of you with websites about your ride... BE CAREFUL! That website can easily turn into a 'shopping catalog' for a thief. Try not to list personal information on the site (ie what city you live in, what school you go to). If you have any pictures of your ride, always blot out the licence plate. Also, if you have your own domain name try to use a different mailing address then the one your car is located at (ie Use a PO Box). Remember that's public information and can easily be obtained by doing a "WhoIs" report (http://www.netsol.com/cgi-bin/whois/whois).
    ALSO-- Manual fuel cut off switches.....hey they cost a freakin dollar. Invest in them. Its a simple cut and splice between the fuel pump line and will piss the hell out of anyone attempting to move your car.
    Speaking of the hood, Hiding the hood pop switch is a step in the right direction but will only stop petty kids who are just f'ing around in the game. The real vulnerabillity is in the line that connects the lever to the hood pop mechanism...in most cars these are routed throught the driver side fender. Pull the plastic molding back strip the insulation and get a plier to pull the wire inside and POP ....you have an open hood.
    solutions? reroute the wire somewhere else or add additional lines to confuse.
    The main point is no matter what you cannot stop someone from getting into your car. You can SLOW them but not totally stop. There are big holes in the side of the car covered with glass....i believe people call these windows. Since it is imposible you to stop someone from getting in one should focus on slowing them down as much as possible as well as preventing the moving/disabling of the car.
    An expensive alarm won't do much for you. They are all the same with some added bells and whistles. All you really need is a starter kill, and dual stage siren....an expensive alpine alarm with LCD screens does not do anything if it can be yanked from under the dash.
    BUY A PEDAL LOCK
    [someone] has thought many hours about this and still have yet to figure a way around it. The infomercial is correct. That pedal is made of some hard freakin steel. And even if you could manage to break the pedal off youd have to sit with your ass facing either up or our of the car for a long period of time....not something smart to risk..
    Record time sawing through a steering wheel....48 seconds.
    I don't know if alarm stickers (such as "Protected by Viper", etc) is a good idea or not. Some say it's a good deterrent, some say it makes it easy for code scanners to 'unlock' your code. If somebody knows more about this issue, please shed some light...
    Another security feature that you can get is Wheel Locks. http://cgi.ebay.com/ebaymotors/ws/e...item=1846139244 I don't know yet if it can be defeated, but it's worth a try.
    LoJack is also a good investment. Although they run around $600 installed, you might get something in return from your insurance company just for having it. Also see 'peace of mind'
    IMO, the *only* equipment that you cannot protect is your subwoofers. Whether you put a grille or not, if a thief can't pull it out, he will stab it with screwdriver. (reconing a sub is way cheaper than replacing it)
    Good advice given above. I have had attempts to take tires and rims. The locks were hidden inside the hub cover. They took the covers but the rims and tires were still there. (Vibration sensor was turned off at the time).
    I was hit again for the stereo at another time and place. Since I no longer own that vehicle, I will talk about it. Because of large trucks the vibration sensor was always off. This person knew vehicles and how to enter without making a mess or taking to much time. I won't go into how. They opened the door, popped the hood, and clipped the siren wires. They wanted the head unit. Only I had taken the covers off while the equipment was new and bolted the covers together. I had also installed the head unit by the sides inside the dash and not with the standard retainer knob mounts. They kept the knobs to let me know they wanted it. They did manage to get one amp out of three. They cut the seat cable and pried it off the floor under the seat. However they did not get the wiring harness so it didn't do them much good. I had removed the bench seat to do the amps install. The insurance company paid off within 3 days. Don't make life easy for a thief or they will make it difficult for you.
    REMOVE YOUR STEREO'S FACEPLATE!! After parking and before leaving the car. Some car stereo owners don't even bother removing their aftermarket headunit's faceplate which is waiting for would-be thieves to possess. (Not applicable to those that own a headunit in which the face 'flips' into the dash).
    The best car alarm to consider buying is Clifford, cuz one of their models carry an anti-carjack feature called, "BLACKJAX" in which the system sets a 'trap' by blaring the alarm and flashing the vehicle's lights which immobilizes your car after a thief drives off with it. I might buy that for my mom's car -- '89 Toyota Camry, cuz it's a 'hot' car for thieves.
    remeber stealth is the key keep every thing as hiddine as possible
    This was taken from another forum. I picked out the realevent stuff.
    Registered User GTIWRX's Avatar
    Mar 2002
    Conshohocken,PA
    damn thats quite a list ya got there!
    Registered User djrez4's Avatar
    Colorado
    Good post, Nick. Can you post the forum/thread you got it from? I'm sure they'd appreciate the credit and then we can all read the rest of the info that you didn't feel was relevant.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    Buy a Armored car,,then NOBODY would Rob you =)
    Where do yu live???Colombia?
    Thanks
    Tuca
    Mar 2002
    Tokyo, Japan
    Good post nick.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Moderator schischwein's Avatar
    Jul 2001
    My car is fitted with a 100,000V jolt generator as the warning mechanism. If the car is pursued further, I have a timed hydrogen cyanide cartridge where the airbag used to be, he'll have MoMo problems....and finally, I have C4 lined around to hide the evidence once the cyanide is emitted.
    Registered User QuickSilver's Avatar
    Bay Area, CA
    Another good idea is to ask your insurance agent about window/glass insurance. Thieves will get in breaking a window possibly. If all they take is something trivial...then your only worry is to fix the expensive window. Most insurance companies offer additional insurance for just the glass. They will replace any broken glass, no deductible, and a few claims a year will not increase premiums. And it's usually less than $5/month.
    I figure I'll get a chip or crack at least once in the next couple of years. lAst i checked it's about $500 to replace our front windshield. At $5/month, that's only $120 in two years. I got this tidbit from an old post...wish i cold remember the member who brought it up...i just thought I repost the suggestion.
    '02 Plat. Wagon, Manual
    Jun 2002
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    thanks nick, i had a feeling that you werent typing all that, but thanks good find
    Quote Originally Posted by DTR rex
    Peter North > *
    Jan 2002
    In the slow lane
    Perhaps it would be a good idea to have this thread as a "sticky" in here.
    The sure is a lot of valuable information on here, and I do know what it feels like to be a victim I lost almost 3K worth of stuff from my previous car (Dodge Avenger) in the parking lot of my university residence. It was hell getting the insurance company to pony up the $$$ and not to mention the inconvenience the whole ordeal was for meMade sure than when I got the WRX, I had the security system and the whole 9 yards put in. The alarm system is VERY tempramental and sensitive, but I figure that it is worth the inconvenience. Also, I make sure that I keep NOTHING of value un the car. It is pretty much empty apart from a few pens and gas receipts in the arm rest compartment. Glove box stays locked at all times too...Oh yes...I also got the locks for the wheels just in case someone gets bright...
    02 WRX WRBP sedan..
    Upgrades??? stock...
    Jun 2002
    Yeah!!
    Jun 2002
    Central IL
    Damnit Nick, That image is horrid. I yakked on my mouse before I could hit 'back'!
    Rubber Duckies Fair Well in the Rain
    Registered User BoarderEight's Avatar
    Jan 2002
    NORCAL NATIVE
    If you lock your glove box would you say it's safe to leave your stereo face in there while going into the mall, for example?
    Jun 2002
    I wouldnt, but I dont have a car.....
    Locking it is just to slow theives down, if they want in, they are getting in.
    Registered User WRXed's Avatar
    Nov 2001
    Macon, GA
    I wouldn't either. It's not too difficult to just pry a glove box open, or just outright break it. Heck, when I went camping (been awhile *sigh*) I'd actually leave the glove box open to make sure people could look in and realize that there wasn't anything to get.
    All those who believe in psychokinesis, raise my hand. - Steven Wright
    Moderator, of the "Super" persuasion
