Results 1 to 4 of 4
This is a discussion on whats the size within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; whats the size of the stock guages wanting to get after market ones with the stock housing wahts the size? ...
    Oct 2002
    Torrance
    Question whats the size
    wahts the size?
    should i just get the housing and put like 2 guages in their on my own instead of 3 ?
    Registered User thechickencow's Avatar
    Mar 2002
    West Allis, WI
    The stock ones are 45mm. Lots of people get the stock housing and dremel it out to use 52mm gauges. The difference between 45 and 52 is pretty substantial.
    tcc
    Moderator
    Apr 2002
    Greenville, SC
    You can get 45mm gauges from Omori...
    http://www.omorimeter.com/prod01.htm
    They also match Subaru interior lighting, from what I've heard.
    2002 WRX Sedan - 2000 Mazda Miata
    Do us all a favor: work on learning how to drive your car before adding more power. Pretty please.
    Oct 2002
    Torrance
    thank you guys
    i thought that omori had diffrent back light colors?
    or is that in japan only?
    well i guess ill have to find out
    thanks alot guys
