Wire Tapping for gauge install - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on Wire Tapping for gauge install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; tap black to ground...
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    tap black to ground
    May 2003
    Originally posted by Richie03
    alittle confused about the clock wires.
    blue/red (constant (+))
    black (ground (-)) easy enough.
    pink/blue (illumination) connect for (+) lighting and is on when the driving lights are turned on
    yellow/green (switched (+)) is this the power that is turned on when theignition is turned on?
    Installing a center gauge pod this weekend. Double checking to make sure things go as smoothly as possible.
    Hello friend, Happy New Year!!
    i have a few question would like to ask you. you said:
    Blue/Red:+12V ok
    Black:Ground ok
    Yellow/Green:ACC ignition?
    Pink:Light ok
    DO you mean ACC = Ignition Switch wire?
    which one is the lighting circuit ??
    Jun 2002
    Illinois
    Subaru uses a variable ground to dim rather then a variable (+). I know there is a dimmer ground in the stereo wiring harness but not sure what wire it is.
    Behind the radio there is an unused 2pin harness. I believe one wire is purple, the other is orange. IIRC you can use these to dim the bulbs. I dont think it is was ever determined possible to dim the Omori's though. Most (not all) Autometers will dim.
  6. #19
    Registered User subaman81's Avatar
    Aug 2005
    Cincinnati, Oh 45102
    followed the instructions and gauges work great. Thanks guys!
    2003 WRX For Sale! PM for details
  7. #20
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Risen from the ashes.... but also some good info.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
