Help: NAVI sensor question
Results 1 to 8 of 8
This is a discussion on Help: NAVI sensor question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; So I had an Eclipse 5500 put in yesterday and so far I like it. The only thing that bugs ...
    Registered User ArchangelF16's Avatar
    Jul 2004
    NC
    So I had an Eclipse 5500 put in yesterday and so far I like it. The only thing that bugs me is that I can't program a lot of stuff (like POI and addresses) unless the handbrake is engaged. The guy that was showing me how it worked said that it should be a pretty simple fix to defeat the navi system to say the handbrake was set but that they wouldn't do it at the shop for liability reasons.
    Anybody have pictures and/or directions on how to do this? I did a search with no luck. Thanks.
    2004 White WRX (R.I.P.)
    2006 White TR replacement
    1998 V5 Grey STi
    Registered User flyingpertyhigh's Avatar
    Mar 2006
    Brookline MA
    Quote Originally Posted by ArchangelF16
    i got the eclipse 5435 and i'm having the same problem. same with dvd's and video.
    Registered User ridered's Avatar
    May 2006
    North vancouver
    I had that problem in my old car with an older pioneer unit, i had my buddy who knows stuff fix it, he went to the handbrake and disconnected the wire the shop ran to it, then put it to a new switch that was grounded, dunno if that will work for eclipse, i also heard it doesn't work on newer pioneer
    Jul 2004
    NC
    the point where my parking brake light comes on on the dash and the point when the NAVI stuff disengages are at different times. Does that mean there is a switch or something in there that has to touch for this to happen? If so, could I just unhook one side from the parking brake and permanently connect it to the other half of the switch?
    1998 V5 Grey STi
    Jul 2004
    NC
    bump. Where are all the audio nuts in here?
    1998 V5 Grey STi
    Mar 2006
    Brookline MA
    i do know that some newer navi systems use a speed sensor instead of a brake cable to disengage functions because of how easy it was to hack the older models. easy hacking = easy lawsuits.
    Registered User houdini's Avatar
    Jun 2004
    Los Alamos, NM
    As a guy with some EE experience (not audio, strictly)... it shouldn't be that hard. Grab a multi-meter and figure out what the wire to the e-brake looks like when the brake is up (probably at + something). Connect the e-brake wire from the stereo to a source that is always that voltage. Done.
    Grab a EE and it'll be quick work.
    2003 White Sportswagon
    Mods: Cobb stg 2 (STX map), Whiteline strut braces, SRBs and swaybars, Kartboy rear endlinks, 04+ rear swaybar mounts, Hawk HPS brake pads meeting Powerslot front rotors, Bridgestone Potenza RE-01Rs, some stereo
    Pending: some more stereo. Front endlinks?
    Registered User JOHN91709's Avatar
    Jun 2005
    So-Cal
    just ground it with a switch
    t3h Z w00t!!!
    Blobeye Syndicate #12
    ooo you touched my tra la la
    Quote Originally Posted by ShardAerithes
    My buddy has an SRT-4, I watched him beat an F-16 from a roll.
