Need help with stereo.
Results 1 to 10 of 10
This is a discussion on Need help with stereo. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have a amplified bazooka tube i wanna throw in my back seat. Does anybody know if i can hook ...
    Registered User flabele's Avatar
    Jun 2005
    New Jersey
    I have a amplified bazooka tube i wanna throw in my back seat. Does anybody know if i can hook this up to my factory 6cd disc player. I have no idea.
    My money pit
    Find a diagramme showing the wiring code for the factory sub for your particular year and model, and see if you can use that harness, extended, to connect your sub.
    May 2005
    Wisconsin
    Im with ya on this one... Can my factory system (6disk) support my MTX amp and sub?
    Registered User subie04's Avatar
    Mar 2005
    Appleton, WI
    it should i have a phoenix gold amp and sub in my trunk that is hooked up to the factory 6disk changer. although I cannot tell you exactly how it is hooked up. I believe somehow it is through the subaru sub channel but i could be wrong be awhile since i had wires run and hooked up in there, but it is definitely possible. an aftermarket head unit would be the way to go if you wanted it to really sound good or new door speakersplus amp for them, with the sub and the factory stereo
    2004 PSM WRX
    Currently Cobb Stage 2
    Blobeye Syndicate #23
    Registered User TOOFAST88's Avatar
    Oct 2005
    Champaign/Buffalo Grove, IL
    You shouldn't have any problem wiring that to the stock 6 disc.
    COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
    RYB - 01
    "RALLY ON"
    Quote Originally Posted by StreetSlider
    Hellen Keller's favorite color is Blobeye Syndicate.
    Registered User rexSTi's Avatar
    Jan 2006
    California
    You could use a line out converter.
    http://www.geocities.com/svxdc/WRX-pinout.htm
    That's the link to the subaru radio harness pin-out.
    Feb 2003
    Elk Grove, Cali
    Most car audio place that are worth their salt will have a component that switches a set of stock speaker wires to RCA for an amp hookup. I am assuming you need RCA jacks for the amp on the tube. Hell, Best Buy or Circuit City shold have what you are looking for. The bad part is you splice into the factor harness. Dont get cut happy with your wire cutters. The harness probably isnt cheap.
    2003 Silver WRX... SOLD
    2002 Honda civic: commuter car
    2007 Acura RDX: wifes car
    MKIV Supra to come this year.
    Jun 2005
    New Jersey
    Thumbs up
    Cool thanks guys . Ill give it a shot.
    My money pit
    Registered User Kanchou's Avatar
    Nov 2002
    Atlanta, GA
    i dont see a 'sub out' on the pins, does it just cop a connection off the rear speakers for the oem sub?
    I hate my WRX's stock horn....
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    Quote Originally Posted by Kanchou
    Yes it does.
    -Max.
    06 STU STI
    2006 STU Pro Solo Natl. Champ.
    www.zzyzxmotorsports.com
