just ground it
This is a discussion on e-brake bypass on jensen vm9511ts within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i have the jensen touch screen indash tv and wonding if any one knows a way to bypass the e-brake ...
i have the jensen touch screen indash tv and wonding if any one knows a way to bypass the e-brake wire so that the tv and dvd display without having the e-brake pulled any suggestions?
Thanks in advance.
just ground it
lightly modded with a hint of audiophile
+ 2![]()
1999 BMW 328i - R.I.P.2004 JBP WRX - R.I.P.2007 SWP STi
And Loving Every Minute Of It.
You don't have to hook the pink wire up to anything. you might have to run this series of commands a few times if you don't have rear screens. You'll have to do this blindly.
Insert a DVD, once the parking brake warning comes on, use your large remote and press stop two times, then pres 1,2,6,4, then push the toggle switch south two times, then click it once. A programers dcreen should come up.
settings:
Region Code: 1
Brake Override : ON
Macrovision: OFF
When your done click SYS SETUP on the main remote twice.
Good f-ing luck. My DVD player is a piece of **** and am getting rid of it tomorrow and getting an Alpine!
