anybody running 8's between the seats
Results 1 to 4 of 4
This is a discussion on anybody running 8's between the seats within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was thinking that 2 8's wouldn't weigh that much, and the weight will be pretty much right between the ...
    Registered User Earshot's Avatar
    May 2006
    I was thinking that 2 8's wouldn't weigh that much, and the weight will be pretty much right between the rear wheels
    so here is what I have found so far
    http://www.tb-speaker.com/detail/1208_03/w8-1363sa.htm
    That's 1056 cm^3 of linear displacement for less than $120 from parts express
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    Quote Originally Posted by Earshot
    i dont think it will fit down there
    Feb 2006
    Siren, WI
    Well if you're concerned about weight, from the qts. value, it appears that these subs need a box as well, which is where most of the weight usually is... they probably would sound good in a box though.
    If you wanted to go with an infinite baffle type design, look for a qts. between .6 and .8...JL makes (at least I know they used to) subs designed for IB configuration, which could save weight by not needing a box. If I remember right, the JL's have a little less excursion than the woofers you are looking at though, The product line was IB.
    I'd try a test sub in that position before committing to anything though...being in the middle of the car, you may get some cancellation going on.
    If that positon don't work, I was thinking of looking into putting 8's in the rear doors or possibly the rear deck when the time comes.
    May 2006
    Between the back seats, in the trunk.
    You can use a lot less material with the 8's, as opposed to my other option of running one 12", behind that little gap, sealing off the back of the back seat, and make a front chamber for the sub as big as the gap between the seats, and that's heavy
    I hadn't thought of going IB, but even with that you have to seal the back of the back seats, which would make a nice place to mount the amps..........
    I'm still in the rolling ideas around in my head phase; just got the car 5 days ago.
    and my test sub is a 10"
