HELP: passenger side window not working
Results 1 to 14 of 14
This is a discussion on HELP: passenger side window not working within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; First off I have a 04 WRX wagon. The pass front window is not working, neither going up nor down. ...
    Oct 2004
    Terryville, CT
    First off I have a 04 WRX wagon. The pass front window is not working, neither going up nor down. Also the master driver side switch will not operate the window. The window lock is not on. Some background: I just replaced the pass side front door card with a new one due to some slight imperfections with the original. While taking the door card off the pass window switch came apart and I lost the small ball bearings, springs, and rocker plate inside the switch that make the electrical contacts for the window switch. I purchased a used switch and tried it on my car and still the window is not working. All other windows are working so it is just isolated to the pass front. I then took the missing pieces from my newer switch and rebuilt my original as i do not know how much use was on the one i bought for a replacement (even though it also came off an 04 and did not show any signs of worn contacts). This rebuilt switch is not working as well. My thought was it could possible be a fuse but my owners does not show any fuses or circuit breakers for the windows and I pulled all the fuses inside the cabin and under the hood and none were blown. Are there fuses/ circuit bereakers for the window? If so where are they located. I tried searching but did not come up with any info. Also any other ideas as to why the window is not working? Any help would be greatly appreciated. Sorry for the long post, I just wanted to give as much info as I know already. Thanks in advance for your help
    04 PSM wagon Stg2
    Registered User RSoxWRX's Avatar
    Mar 2006
    Norfolk, MA
    wow, nice novel.
    I stopped reading after line one....
    Question for ya,
    1. is your drivers window working? if not take out the control fron the door and plug in the window control that should fix it.
    2. if its a fuse all your windows wont work
    3. did you buy a NEW passanger window control switch yet?
    4. if still not working your motor might be broken.
    you've prob tryed all this but just on case
    NewEnglandF4
    Oct 2004
    Terryville, CT
    Yes the post was a little long but I jus wanted to put out all the info that I knew already.
    As to your questions:
    1: The driver window does work. Only the passenger side front does not.
    2: I am looking for a wiring diagram as I did not know if there are seperate fuses/circuit breakers for each window. I know each had a relay.
    3: I tried a new switch and also rebult a switch with working components and they do not work.
    4: Is there a way to test the motor? Can I jump the pin outs to make to motor work? I would need a wiring diagram for this as I do not know what each pin out if for
    04 PSM wagon Stg2
    Mar 2006
    Norfolk, MA
    Quote Originally Posted by KGAWDTSi
    yes, find the motor and grab power and ground, send a quick 12v through...might give an answer...be careful a kid a work with was doing this to his civic and he zapped himself real good. never hurd him screem before that happend
    NewEnglandF4
    Administrator
    May 2003
    Quote Originally Posted by RSoxWRX
    He zapped himself with 12v?
    May 2005
    Phillytown, PA
    What ever happened to, take the door panel off and use a test light to see if the motor is getting power?? Try it. It works.
    Mar 2006
    Norfolk, MA
    i think he got power from his ign. harness and he burnt his thumb real good
    NewEnglandF4
    Oct 2004
    Terryville, CT
    I am not very good with electronics. But I did have the door card off and a fellow member here sent me a wiring diagram for the power windows. It appears that the switch is working as it is sending power to the elec. connector going to the motor. Power is alos coming out of the connection.
    How difficult is it to remove the motor as I cannot test the motor when it is in the door since I am unable to get to the wiring at the motor? If I pull the motor out when I reinstall it would the window alignment be off?
    04 PSM wagon Stg2
    Administrator
    May 2003
    Bump!!! For the first time in over a decade of wrenching, I zapped myself with 12 volt! I was changing the alternator on my truck, and somehow touched the hot wire, and grounded myself just the right way!
    May 2005
    Phillytown, PA
    How did that feel?
    Administrator
    May 2003
    Quote Originally Posted by wrx wagone
    How did that feel?
    Not that bad. The worst is getting zapped by a plug wire.
    Registered User kingypoo's Avatar
    Jun 2006
    Massachusetts
    uh ya
    06 OBP WRX
    New England F4
    Audio Integrations's Avatar
    Dec 2005
    Camas, Wa
    you could try holding the switch while giving the motor a slight tap with a wrench or something, nothing to excessive. I've done that a few times on window motors and starters.
    "I see us as being in the art business. Art, entertainment and mobile sculpture, which, coincidentally, also happens to provide transportation."--Bob Lutz
    www.audiointegrations.net
    Registered User SteelCity_WRX's Avatar
    Jun 2004
    Pittsburgh PA
    If someone could send me that diagram for the windows I would really appriciate it. Last night my drivers side window jumped off its track or something, when it goes up it does not line up and leaves a crack near the sides. Also other then the dealer anyone know where you can get a new window mount?
