egt gauge
Results 1 to 5 of 5
This is a discussion on egt gauge within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; hey all, i've done alot of searching and i can't really find any useful information. i've got a few of ...
    Jun 2005
    Pittsburgh PA
    egt gauge
    hey all, i've done alot of searching and i can't really find any useful information. i've got a few of questions about egt gauges. ok first, where is the best place to place the probe? second i am eventually going to get the cobb stage 2 with the up pipe with the factory egt bung. is there anyway to tap off that to it for a egt gauge or do i have to make my own hole? pics welcome. thanks alot.
    Mar 2002
    Calmer than you are
    you don't need one for a cobb stage 2.
    go f*** yourself
    Registered User bluerex47's Avatar
    Jun 2004
    ohio/texas
    its not a need, but I think its a smart investment. To answer your que's, you can put the egt in the uppipe bung, but the stock sensor needs to go there or it will give some CEL's. Most people put it in the drivers side exhaust, about 1-2 inches down from the block. It took me about 45 minutes to pull of the heat shields, pull off the one section of exhaust, drill/tap hole, clean it out, and reinstall everything. This will by far give you the best readings (around 1550 degrees F is the max limit most go by).
    Sorry though, no pics. But I hope this helps
    - chris
    04 wrx, 04 corvette, 66 GTO
    ACT installed at 36k...new Gears at 44k...
    Mar 2002
    Calmer than you are
    the #4 cylinder gets the hottest...most people wil tap right near #4, or that "nub" between #2 and #4 on the factory casting. Still unless you got something else going on the Stage 2 by itself has already been tuned to not exceed the recomended EGT. Putting the EGT probe in the uppipe is pretty useless...it just makes the gauge work and look pretty, but the readings you get from the uppipe are too far from the cylinder to be useful for tuning.
    I've actually seen people tap the header, while on the car, with the motor running....apparently that blows away the metal shavings are you drill...of course it blows them right into the turbo...so I don't get it. Its best to take off the header. Some people put in on the passanger's side #3 cylinder because that side of the manifold has to come off when they're installing the uppipe anyway...and on that side #3 is the hottest, but if you REALLY want to be safe you'll want to take off the driver's side header and tap #4.
    go f*** yourself
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    Check out scoobymods.com for a writeup with pics
    It actually benefited me to have the gauge with Stage II because one of the earlier map revisions had me up to 1650 degrees. This was eventually fixed with a subsequent map version.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
