I Wanna keep the clock!!! (plus guage mounting advice)
Results 1 to 5 of 5
This is a discussion on I Wanna keep the clock!!! (plus guage mounting advice) within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Greetings everyone.... My three Autometer C2s came in today.... the clock replacement pod should be in my this weekend. With ...
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    My three Autometer C2s came in today.... the clock replacement pod should be in my this weekend. With any luck, I'll hook them all up this weekend.
    My question....... I really don't care about the clock, but I would like to keep the airbag indicator, which on my 06, is part of the same unit.
    I "THINK" I can just dislodge the clock/airbag indicator from the back of the factory panel.... and my plan was to mount in in the empty bin under the stereo.
    1) Any reason I would have a problem with this? (I've never removed that panel yet, so I don't know what I'll find under there.
    2) Whats the easiest way to get the original clock pod off? Does it just "pop" off like the stereo plate? Do I need to get at it from underneath, or can I just pry it up from the top of the dash?
    3) The A/F gauge is easy..... the boost guage is easy too. The oil pressure gauge is easy..... if I only knew where to hook it up to. Can someone point me in the right direction?
    Thanks everyone!!
    Registered User xfloggingkylex's Avatar
    Jan 2006
    Frederick, Maryland
    Registered User 05CGMWagon's Avatar
    Aug 2005
    Southern MD
    my car is an 05 so i only have the clock part, i made a longer connection and put the clock in the ashtray (dont smoke) but here is what i did FWIW
    tools: flat tip screwdriver, wire snips, 4x 1 1/2 ft lengths of 16ga wire, 8 butt connectors, crimpers, electrical tape
    1. pop the factory clock piece off. just pry gently from the front and pull forward
    2. w/ a flat tip screwdriver undo the 2 fasteners holding the clock in place
    3. disconnect the clock
    4 cut the wires about 3in behind the connector
    5 connect the 4 lengths of wire and crimp tightly
    6. do the same to the piece that connects to the clock
    7 tape up the wires so it is nice and clean
    8. unscrew the shift knob and take off the console
    9. feed the wire threw the hole where the ashtray used to be
    10. push the clock into the new mounting position and put the console back to gether.
    your done.
    i know this is not goin to be the same for you put the wiring shouldnt be that much different and you might have to find a different place to put it, but this could help someone else.
    http://i56.photobucket.com/albums/g1...agon/clock.jpg
    "The only thing necessary for the triumph
    of evil is for good men to do nothing"
    Edmond Burke
    "I don't think you will"
    05CGMWagon
    Registered User uncle lewie wrx's Avatar
    Oct 2004
    PM Aspen524 i think r the numbers, he did this.
    06 Aspen White STi w/ Gold BBS's
    Mar 2006
    SLC area
    Guess the oil pressure guage isn't quite as easy as I thought..... far from a SBC.
    Of course... no SBC I ever worked on had an intercooler.
    I really have to remove the intercooler huh? Bummer.
    Work starts thsi weekend.... I'll post pics when I'm done.
