Installing amp for door speakers
Results 1 to 7 of 7
This is a discussion on Installing amp for door speakers within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I want to install an amp for my door speakers. How do I wire it up to the speaker itself? ...
    Jan 2017
    I want to install an amp for my door speakers. How do I wire it up to the speaker itself? I have an amp for my sub so can I just run another power wire off the first one to the second?
    Thanks
            MainFrame's Avatar
    Austin, TX
    Simply run speaker wire directly from the outputs on the amp to the speakers. It doesn't really matter which of the two wires you connect to each of the spades on the speaker, but however you do it you want them to be all wired uniformly.
    If you're asking if you can run the same channels that are already running to your amp to additional speakers.. you will have to check the resistance of the speakers and the resistance that the amp is capable of running. For example, if your sub is 4ohm, and the speaker you're running on the same channel is 4ohm, then together they're 2ohm. If your amp isn't capable of doing 2ohm resistance then it will either throw the amp into protection mode (which it's unlikely that it will work afterwards).. or it will just fry the amp. Now if you're adding in tweeters you have a little more wiggle room as far as resistance, since the ohm load on the tweeters doesn't work quite like other speakers. Also, the crossover for tweeters should keep the ohms the same across the board.
    Maybe I read that wrong and you're planning on installing a second amp, using the existing power wire? That should be fine as long as you pay attention to the amps (A) each amp draws and that the gauge of the wire is sufficient for the amp draw and length of the wire. You can find charts online that will show what gauge you need for how much amp draw with the length of wire you're running. I would just go by the fuse that's in each amp to estimate how much draw it has.. it will be overkill, but you'll know for sure that your wire is large enough. I suppose you could potentially end up with a ground loop interference using the same power wire, but it's not likely.. and if it does happen you will just need to run another wire.
    I would definitely run separate grounds for each amp though. As short as possible, bolted into the chassis sanded bare.
    Jan 2017
    Ok! Let me clarify, I was saying do I have to run another power wire from the battery or can I just run a short wire from the existing power wire to the new amp.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by NikRose299 View Post
    Got it
    I edited my post above right after I reread your question.
    Jan 2017
    Ok! Do you think I would notice the difference between just a 2 channel for the front speakers or should I do a 4 channel for all the speakers?
            MainFrame's Avatar
    Austin, TX
    A four channel amp will be better, and it will make a noticeable difference.. but good amps aren't cheap ($600-$1200+), and a four channel will be a good deal more expensive than a two channel amp of the same quality. Since the front speakers are far more important sound wise, if it comes down to a good two channel amp or a crummy four channel amp, I would get the two channel amp.
    Jun 2016
    Houston, TX
    Alpine power pack was more than enough power for me. And most of the time I don't turn up the volume because I'm too busy drooling over the sound of the rumble
