Opinion on DIY vs Professional Sound Deadening vs Neither
Results 1 to 12 of 12
This is a discussion on Opinion on DIY vs Professional Sound Deadening vs Neither within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hello there, First post to the forums here. I've owned my '15 WRX base model for just about two years, ...
    Aug 2016
    Hello there,
    First post to the forums here. I've owned my '15 WRX base model for just about two years, and I am on the verge doing something drastic to address the noise coming from my car. I may have overly sensitive hearing or something of that nature, but with the combination of wind, road, and drivetrain noise, potential mixed in with the subpar stereo quality, I start to go crazy for trips in my car on the highway and end up not using my car when I'd like to for fearing of being exhausted and having a headache when arriving. .
    I've found great information for where to start on Sounddeadenershowdown.com, and if I go the sound deadening route, I plan to use their suggestions/materials. I'm currently debating between three options:
    a. Ordering the materials and attempting to do the modifications myself. To be honest, this seems a bit beyond my skill level due to needing to take off many panels, and makes me a bit nervous, but would make keeping the car reasonable to me
    b. Using a local audio/car sound shop, which would bring the entire cost of the job up to $2500-3000
    c. Getting rid of the car for something else, if either one of these above options doesn't make sense.
    I know many people look for ways to reduce the weight of their car, and the work seems like it would be nearly irreversible due to the gluing/taping. And I feel like I should go ahead and start upgrading audio components if I am taking everything apart, but that is likely to open an additional money sink.
    I foresee heading back to school in the next year or two, and may even not need a car depending on where I end up, meaning I'd like to keep the option of selling on the table. I was curious if other owners/potential owners of WRXs could chime in here for whether the DIY/professional route of adding 150lbs of sound insulation will negatively impact the value of the car, in addition to requiring me to spend some serious money.
    Best Regards, and looking forward to your responses!
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    I put house fiberglass in my doors and under the rear kick panels. Made quite a diff and almost no weight. Still not "quiet" but much better. I plan to crawl under the car and see if there are places I can stick dynamat to help down there.
    If you consider the area that you are stuffing or dampening a sort of sealed enclosure (and if you're doing a door and go with this, you are an admirable optimist) then I suppose stuffing ought to lower the system impedance and the f at which that impedance occurs.
    If on the other hand you consider the area you are stuffing some sort of vented (intentionally or not, tuned port or not) system, then both the system tuning and the system sensitivity ought to drop, but so will port effects -- or in a car's case, effects due to air leaks.
    I've no idea what happens if you consider the system infinite baffle or a horn, but then again I as much about acoustics as I do about flying the space shuttle. In any case you'd be decreasing rattles, huffing, buzzing, etc. so the rest is probably secondary since the car is never going to be a critical listening environment and you'd improve your sound anyway. (In other words I do think removing existing stuffing from a system designed to have it would increase Q, but I don't know by how much, nor do I know that the opposite is always true).
    Consider lining the rear 1/3 of the car, be it a boot/trunk or a hatch area, particularly around the wheel wells since that's where a lot of roar comes from.
            MainFrame's Avatar
    Austin, TX
    If you want to reduce road noise, rattles, and improve stereo sound quality, then I would do it. Personally, I would never pay a shop to have something like that professionally done.. I could do it better myself, for about 1/10th the cost.
    May 2016
    I would DIY myself as well. I lined my trunk with 80mil GTMat and it was quite easy to do. It made a slight reduction in road noise and exhaust drone. I also did it to my wife's Toyota in the doors, trunk, and part of the floor. It isn't hard to do, just time consuming especially if you are unfamiliar with taking things apart. What helped me a lot was taking lots of photos along the way so I knew what went where when I was reassembling. Take your time and be thorough, and you will end up with a good result.
    Oct 2015
    doing just the doors in mine improved it immensely
    i use the new soundskin product. its phenominal
    SoundSkins | #ThinkOutsideTheBox | SoundSkins Global
    Registered User 4EverMetal's Avatar
    Aug 2016
    Lost Wages, NV
    I did this with my 08 Tacoma and the out come was awesome! I plan on doing this with my 17 WRX. It's not hard to do yourself. All you need is a place to work on the car and the tools to remove the seats, door trim, ect. Again not hard at all, just takes a full day to do. Plus there is a ton of YouTube videos out there to help you out.
    I have used and plan on using Second Skin Audio's products for my WRX. Vehicle Sound Deadening Materials for Noise Reduction, and Thermal Insulation. Call 800 679-8511. | Second Skin Audio, Made in the USA.
    Registered User Steemax's Avatar
    Jul 2015
    SoCal
    I've been contemplating on sound deadening the doors and the entire trunk area, but really I'm not quite annoyed enough yet of the road noise to go forward with it lol.
    Present: 2016 Subaru WRX Pro-Tuned
    Instagram: Steamax
    Build Thread: Click Here
    YouTube: Click Here
    ClubWRX.net Vendor rexxx0486's Avatar
    Jan 2007
    North NJ
    Quote Originally Posted by phd12v View Post
    +1
    I did just the doors and spare tire trunk area with dynomat extreme and had pretty good results considering it took less than an hour.
    -Clayton, Your official CLUBWRX Subaru Dealer!
    CLUBWRX New car buying program SAVE HUGE on new Subarus:
    http://www.clubwrx.net/forums/tri-st...ubwrx-net.html
    Ask a Subaru Dealer thread:
    http://www.clubwrx.net/forums/car-pu...ru-dealer.html
    FREE 3rd party vehicle inspections:
    http://www.clubwrx.net/forums/tri-st...spections.html
    Aug 2016
    Lost Wages, NV
    I think I'm going to pull the trigger and order the supplies soon. Because I live in an apartment I'm going to start with the doors and trunk first since I think I can get away with doing it in the parking lot. Once I get someone to let me borrow their drive way I'll finish the rest.
    Here is what I think will do for the car with some to spare.
    Attachment 270210
    Oct 2015
    have you looked at the soundskin yet?? you might want to check it out. it is like 2 in 1..... it works realllllllly good. i have been in the industry for almost 26 years and i was a big supporter of the dynamat extreme.....until i used this stuff.
    Aug 2016
    Texas
    I was just thinking about this today. I live in a town where the roads are straight trash. I find it to be so annoying to go on road trips leaving this town because I'm on a crappy highway for 2 hours.
    A new set of wheels and tires will reduce tire noise. But, that's pretty pricey as well.
    Anyway, maybe you wanna check this stuff out.
    https://www.amazon.com/Noico-deadeni...deadening+pads
    I thought about buying this and doing the sound proofing myself. Its seems pretty cheap and its rated very well.
    Let me know what you come up with. Because, I seriously considered getting rid of my car because of the road noise.
