Where to mount front component cross-over in door on 2015 wrx?
Results 1 to 5 of 5
This is a discussion on Where to mount front component cross-over in door on 2015 wrx? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi All, I ended up buying the polk db6501 front components and was wondering if anyone had pictures of where ...
    Jan 2015
    Hi All,
    I ended up buying the polk db6501 front components and was wondering if anyone had pictures of where they ended up mounting their cross-overs.
    i would like to keep them in the door if possible. I am going to be using the stock wiring with metra adapter since my amp is only 50rms.
    please attach photos!
    Jan 2012
    New Jersey
    Why not just find an spot between the door and door card. Then zip tie/mount them to the door. Thats what I did with mine just need to make sure to use a good X pattern if you are going to zip tie it.
    2012 WRB 4DR | SPT Exhaust | Short Throw | Rally Armour | WC Lathe Werks Custom TI Knob | Kartboy Bushings | Stoptech Brake Lines | JBK Elements DRL | STI HID Retrofit | XB LED Angel Eyes | GrimmSpeed Lightweight Crank Pulley
    CFLip2x 2012 WRB WRX Build
    Jan 2015
    That is what I planned on doing. I was actually going to use industrial Velcro. Is there ample room between the door and doorcard? Do you have photos of your install location?
  5. #4
    Jan 2012
    New Jersey
    Sorry no, I just found a spot and made it work. No need to worry that much it's not rocket science just trial and error.
  6. #5
    OMG WTF MainFrame's Avatar
    Texas, United States
    If I was going to do that I would probably use that 3m double sided foam tape and find a place they fit between the door and doorcard.. I put my crossovers by the amp though, to avoid the possibility of getting them wet.
