2014 WRX: Possible to make boost pressure readout to center display?
Results 1 to 3 of 3
This is a discussion on 2014 WRX: Possible to make boost pressure readout to center display? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Own a 2014 WRX without a boost gauge and I've never liked how the stock or aftermarket ones looked. Would ...
    Aug 2014
    Own a 2014 WRX without a boost gauge and I've never liked how the stock or aftermarket ones looked. Would it be e possible to get the boost pressure to readout to the center display where the temperature and MPG are now? For instance, add it as a fourth readout after you cycle through the two trip MPG reading? The ECU must be sampling the pressure, the hard part would be getting it to readout to the display. Is it possible? Done before?
    Registered User Nayrb37's Avatar
    Sep 2013
    New Jersey
    I'm sure it's possible if you wire up an Arduino board or even a Raspberry Pi. You would probably need to find a new LCD display.
    I think someone else on this forum did something similar. I'll update my post if I find it.
    Edit: Here, he used an Arduino board. Clock Pod Mod
    2014 Subaru WRX WRB Stage 1
    Stink-Eye Mob # 1.618
    Previous Vehicles: 2010 Subaru Impreza 2.5i; 1997 Ford Mustang Cobra; 1998 Audi A4 1.8T; 1995 Ford Mustang
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
    Jan 2012
    New Jersey
    Check out the Ultragauge for 60ish its not bad but it doesnt respond as quick as a dedicated gauge. SMY cluster is your best bet to keep an OEM look (just my opinion)
    CFLip2x 2012 WRB WRX Build
