Can i swap boost gauges?
Results 1 to 15 of 15
This is a discussion on Can i swap boost gauges? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have searched and cant seem to find anything answering my question. My spt boost gauge readings are quite off, ...
    Oct 2013
    Cool Can i swap boost gauges?
    I have searched and cant seem to find anything answering my question. My spt boost gauge readings are quite off, the gauge is flashing when its on.So i thought it was time to just get a new gauge.I was wondering if it was possible to just swap the gauge itself and change it to a different brand. If i could swap it would i need to do the whole process of installing a boost gauge again?
    Thanks much love.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    The gauge you buy to replace the SPT gauge will come with everything you need to replace the everything, so why not? They are very easy to install. I would recommend replacing the whole thing. I would go for Defi, or AEM, which are nice gauges. They are a little more expensive, but I am in the mindset that I buy quality parts once rather than lower quality parts numerous times (just my opinion).
    Jul 2012
    Rocky Top
    ^agreed. If you want something cheaper I would recommend Maddad. My favorite gauges aesthetic wise.
    Oct 2013
    Thanks for answering my question guys, help out alot!
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    How did you verify the gauge was reading incorrectly?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Oct 2013
    Well I don't know for sure, but its saying that I am making 20 pounds of boost which I'm sure I'm not, and its very sporadic.I've heard stories of spt gauges going out so it was more of a theory that my gauge did. Is there a way I can found out to see if its "broken" for sure? Or does that sound like its done for?
    Jan 2012
    New Jersey
    If your car is still under warranty have a the dealership look at it. What year is the car? Does the gauge say you constantly making 20lbs or around there?
    CFLip2x 2012 WRB WRX Build
    Oct 2013
    Quote Originally Posted by cflip2x View Post
    I bought it used but its an 09 with 55k miles.Its at a constant 20 pounds , unless I'm at idle that's why I'm thinking that its done for.
            MainFrame's Avatar
    Austin, TX
    I would think faulty wiring would be more likely than a bad gauge.. in which case replacing the gauge and reusing the same wiring will do you no good.
    Oct 2013
    so doing the wiring over again would be my best bet to get it back in working order?
    zax
    zax is offline
    Nov 2008
    Is the SPT gauge electronic with a sender?
    Facebook me here
    Oct 2013
    It is a mechanical gauge
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by cmoney View Post
    Hmm.. never mind then. If it's mechanical and only reads vacuum or 20psi then there is probably something wrong with the gauge.. although flickering is indicative of a bad ground or other wiring issue.
    Oct 2013
    So scrapping it and get a new gauge and wiring would be the best idea?
            MainFrame's Avatar
    Austin, TX
    Probably, yea
