2004 wrx High beam indicator dash light not working
Results 1 to 4 of 4
This is a discussion on 2004 wrx High beam indicator dash light not working within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; yesterday i was replacing an Hid bulb in my 2004 wrx, and also doing the day running light delete, after ...
    Mar 2014
    Unhappy 2004 wrx High beam indicator dash light not working
    yesterday i was replacing an Hid bulb in my 2004 wrx, and also doing the day running light delete, after i was finished i noticed that the high beam indicator on the dash wasnt working so today i un-do the DRL delete and plugged everything back in. the high beam indicator on the dash is still not working tho ( the high beams work, also the low beams, turn signals, but not the little blue high beam indicator. i tried looking everywhere but no luck of this issue, on general chat someone said that it might be the dash light because its a very old car. please help
    Registered User LogiMech's Avatar
    Mar 2008
    the sticks, Colorado
    Looks like he helped you, replace the high-beam dash bulb.
    Mar 2014
    is it difficult to do it?
    Mar 2008
    No, probably like 5 minutes. The "shroud" around the cluster has 2 screws at the top. Then the actual cluster has 3 screws. Unplug the cluster and look at the back. The circuit board is labeled, just look for high-beams or take an estimate of which bulb it is. Put it back together.
