Cheap and Fast Sound Dampener Mod -- TOTALLY REVERSABLE.
Results 1 to 8 of 8
This is a discussion on Cheap and Fast Sound Dampener Mod -- TOTALLY REVERSABLE. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was looking for a simple, elegant, and inexpensive way to reduce cabin noise from the engine and exhaust. I ...
    Registered User skimd's Avatar
    Jan 2014
    Cheap and Fast Sound Dampener Mod -- TOTALLY REVERSIBLE.
    I have been reading extensively on the forums and tried to find a solution similar to Dynamat that would not involve removing a large portion of my interior. I also did not want to find myself with a permanent modification that was not easily reversible.
    "Peel & Seal" is a product that has some of the sound-dampening properties of Dynamat, but is far less expensive (about 25% the cost per square foot). Unfortunately, when this product is applied, it can have an unpleasant odor at warm temperatures and once it is applied to most surfaces, it is not simple (if even possible) for it to be removed.
Name:	peel and seal.jpg
    For me the ideal solution was one that worked, was cheap, could be accomplished quickly, and could be completely reversed.
    As far as I know, no one has come up with the method I am about the share. I wish I owned a sound level meter so I could scientifically document the difference in interior noise level. If I get one, I will update this post with a pre and post decible level reading.
    Items required for the project:
    A WRX Hatchback (mine is a 2014)
    A 5'x7' tarp ($4.99)
    A roll of "Peel & Seal" 6"x24' ($15.99)
    A good pair of scissors
    A black Sharpie marker
    The first step is to remove the stock hatch liner.
    Next lay the liner on the tarp and outline it with the sharpie marker:
Name:	trunk liner.jpg
    Now lay strips of the "Peel & Seal" onto the tarp until you have covered the area outlined. This effectively creates a new hatch liner made of "Peel & Seal" and tarp. Cut out with the scissors and place in the hatch.
Name:	peel and seal tarp.jpg
Name:	peel and seal tarp in trunk.jpg
    Now, make 4 strips of tarp/"peel & seal" with the remaining tarp pieces. 2 should be 24" long (to place behind the fabric of the passenger rear seat in the hatch) and 2 should be 14" long (to place behind the fabric behind the driver side rear seat in the hatch). Sorry-- no pic of this process. It's very easy, however (and I will show where these strips go below):
Name:	where the strips go.jpg
    Now replace the hatch liner:
Name:	trunk liner back in place.jpg
    Give the car a drive and see if you notice a difference. I did. I plan to test the actual sound difference with a sound meter at some point in the future.
    Does it make a world of difference? No. Is it cheap, quick, & reversible, YES!
    If you try it, please share with me your experiences.
    Have fun!
Name:	it's a tarp.jpg
    Feb 2014
    PNW -WA STATE - rainy side
    So do you actually stick the strips to the tarp?
    Where do you buy the Peel and Seal? HD?
    Jan 2014
    Yes. Precisely.
    Jan 2014
    I purchased the Peel & Seal at Lowes
    The product has a detectable odour due to volatiles. Is an odour detectable with your solution now?
    Feb 2014
    I'm subscribed for the first 85°F day.
    Jan 2014
    No odor whatsoever. That's the reason I have proceeded the way I did. If it starts to stink, it's out of the car. It's disposable and cost all of $20 ($20.98 plus tax).
    I'd rather have louder than stinkier...
    Feb 2014
    Thanks for the ideas!!! I'm going to do both dynomat and this.
