Sparco Gas Pedal Install (2011 WRX)
Results 1 to 13 of 13
This is a discussion on Sparco Gas Pedal Install (2011 WRX) within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey Miggs here again with another install. This was pretty easy, but I couldn't find anything on the inter-webs when ...
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    Hey Miggs here again with another install. This was pretty easy, but I couldn't find anything on the inter-webs when I searched, so hopefully this will help someone out. I am installing the Sparco gas pedal from the Sparco pedal set ( Sparco Race Pedal Set Silver 03779AN at RallySportDirect.com ). The purpose of this install is to make heel-toeing easier.
    Things you will need:
    - 7mm and 12mm socket
    - 7mm wrench (or vice-grips as I used)
    - Hex key set (I used a T-10 Torx)
    - Drill and drill bits (I used .147)
    - Pliers (I used needle nose and small adjustable)
    - Opposable thumbs and a full set of phalanges
    First thing you need to do is the pull the pedal assembly out. This can done by removing two 12mm bolts (circled in green) and a harness clip (boxed in orange).
    Once you have the assembly out, you need to remove the OE aluminum cover. Gently pry back the prongs to remove
    The next part is the trickiest. You need to map out where you intend to drill bolt holes. I recommend using a paint marker, and starting from the top. I only used 3 of the 4 pre-drilled holes, although you could easily get away with only using two. Once you have the first hole drilled, put the new pedal cover on, securing loosely with a bolt. Rotate the cover until you have decided your next drill location. Start the hole, then rotate the cover out of the way and finish drilling. Repeat until complete.
    Here is the finished product, ready to be reinstalled!
    After you install, you may get a check engine light and traction control light. These are for low voltage at the accelerator pedal; if you have an AccessPort, clear the codes and restart. If not, you can clear them by pulling the negative battery terminal and depressing the brake pedal. They may clear on their own after driving, but I cleared mine prior. After initial impressions, I am very happy! Not sure If I will install the other two pedals, but if I do I will edit this post. Enjoy!
    Registered User BlankWRX's Avatar
    May 2013
    Queens, NY
    Great installation guide. I thought about installing a new set of pedals. Have you improved in doing heel-toe?
    Jul 2013
    North Carolina
    Quote Originally Posted by BlankWRX View Post
    Thanks! The difference is incredible. For heel-toeing in our cars this is a must.
    May 2013
    Queens, NY
    Quote Originally Posted by Miggs View Post
    How is the grip on the pedal? My feet sometimes slip off the stock pedals when it rains, so I'm curious as to how these feel.
    Jul 2013
    North Carolina
    They feel pretty good. I know what you mean, mine slip after a simple car wash! (Stock of course). When the pedals are wet/slick, I generally scoot my seat up a bit to improve the angle of depression on the pedal(s).
    May 2013
    Queens, NY
    Any reason why you didn't want to install the clutch/brake pedals? I just ordered a set from RSD, will give an update once I have everything installed!
    Jul 2013
    North Carolina
    Just haven't gotten around to it, the biggest beef I had was with the gas pedal. GL!
    Jan 2014
    I guess I must be doing something wrong, because my last two cars (Civic Si and RSX-S) required that I "roll" my foot over and tap the gas with the upper arch of my foot (with my toe on the brake pedal). The Civic Si was the best, since it was hinged on the bottom of the gas pedal, so I could literally "heel" the gas.
    But with the WRX, the brake pedal sits SO HIGH that I can't possibly roll my ankle enough to tap the gas. I've tried "spanning" the brake and gas, but it is awkward and I end up hitting the brake too hard just to get enough movement on my foot to touch the gas pedal.
    I'm just curious how this pedal kit solves that problem? I see the side protrusion, but as I said, the brake pedal is so much higher than the gas, I can't really even twist my foot properly to touch it. Isn't there any gas pedal kit that extends it lengthwise rather than width-wise ? I'd like to jam my heel down and hit the gas pedal, but it's too short for that.
    Like I said, this is weird since my other cars were SO easy to heel-toe. I can't seem to figure out my WRX, though.
    Registered User kite991's Avatar
    Nov 2013
    California
    I had problems doing heel-toe in the WRX at first, but I realized that I just need to lift my foot higher when I press the brake pedal. But there are also times I mess up because my foot slips in between the gas and brake (size 8.5 shoes)
    Jul 2013
    North Carolina
    The pedals are close enough with the Sparco gas pedal cover to allow multiple options for heel toeing. The first few days after install I accidentally depressed both pedals simultaneously because I was used to that big gap. I will post some pics later to show you exactly what I mean. It's a great improvement.
    Jan 2014
    Quote Originally Posted by kite991 View Post
    Awesome hint! I tried shifting my foot up about 2-3 inches today and it worked like a charm! I still need to practice a bit more, as I tend to depress the brake a little too hard now because my leg is raised up higher, but at least I'm squarely catching the gas pedal. I guess I am just so accustomed to keeping my heel on the floor as I hit the brake, and then try to rotate it over to catch the gas pedal. But now I have to lift my foot a bit while I hit the brakes. I'll get used to it. Thanks again for the hint.
    May 2013
    Queens, NY
    I installed the Sparco gas pedal and it has helped a bit because the pedal extends out about an extra inch or so. I'm still working on my heel-toe, although I'm nailing it here and there. I've realized I don't do the traditional "heel-toe", I do more of a "toe-toe" maneuver.
    Nov 2013
    California
    Quote Originally Posted by Drew_V View Post
    No problem, it does take a bit of getting used to doing a lighter tap on the brake since your foot is higher up. Before I realized that this car has a slight slope next to the gas pedal which my heel kept knocking into when I tried to go into heel toe.
