03 WRX NO TAILLIGHTS, DASH LIGHTS, or STEREO BACKLIGHTS HELP!
Results 1 to 5 of 5
This is a discussion on 03 WRX NO TAILLIGHTS, DASH LIGHTS, or STEREO BACKLIGHTS HELP! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have a 2003 subaru wrx sedan I have no gauge cluster lights but the odometer lcd works fine, the ...
    Dec 2013
    Woodland Park, Colorado, United States
    I have no gauge cluster lights but the odometer lcd works fine, the radio backlight is out but plays music (radio lcd works as well), I have no taillights (brake lights, turn signals, hazards, and headlights work).
    Ive tried to use the parking light to bypass but nothing works.
    When I turn the headlight knob to the first position i hear a small click where the dash fuses would be and when I turn it to the second position I hear a louder click in the glove compartment area.
    Ive checked fuses and replaced some just in case but no luck, someone told me it could be a relay, a broken ground, or a switch. Not 100% sure where else to start.
    I did check the relays under the hood they seem to be fine there are 4 relays next to the fuses under the dash but i have no idea what they are and i cant seem to find a diagram Ive read one could be for illumination. Below is a couple of pics of the relays not tooo great though.
    WP_20131220_13_11_28_Pro | Flickr - Photo Sharing!
    Any ideas anyone because I am terrible with electrical... I had the fuses checked by my mechanic buddy he agreed that they are fine power isnt making it to the necessary areas...
    Did you recently install a car radio?
    The click under the glove compartment is likely the headlamp relay. Check all connections.
    Dec 2013
    Nothing installed, before it went out everything flickered then came back on 15 min later it happened and everything went out and never came back on.
    Suspect a bad contact and/or relay then.
    Oct 2013
    Virgina
    I had a similar problem in an 02, ended up being a bad connection in the harness for the stereo.
    EDIT: mine would blow the fuse....
