Instrument Cluster Removal
Results 1 to 3 of 3
This is a discussion on Instrument Cluster Removal within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Can anybody help me with the correct way to remove the instrument cluster without damaging it? I have a 2013 ...
    Oct 2013
    California
    Can anybody help me with the correct way to remove the instrument cluster without damaging it? I have a 2013 WRX looking to install a shift light and I will need to get behind the cluster in order to get the Tach Signal Wire.
    Registered User Formula156's Avatar
    Jan 2013
    Orlando
    I don't know how to remove it sorry. but I will give you a tip if touch your needles your speedometer or your RPM won't show correct numbers!!
    Jan 2012
    New Jersey
    Crowbar and a heat gun worked for me.
    You need to pull on shroud it feels like its not going to remove but it will. There are some yellow clips that may come off with them just make sure not to lose those.
    this may help
    SMY and Defi Gauges install - great pics if you want them! - NASIOC
    CFLip2x 2012 WRB WRX Build
