AEM UEGO Wideband o2 Gauge Install
Results 1 to 15 of 17
This is a discussion on AEM UEGO Wideband o2 Gauge Install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just wanted to know if anyone could point me in the right direction as to how to install the aem ...
    Registered User anpato's Avatar
    Jun 2012
    Just wanted to know if anyone could point me in the right direction as to how to install the aem uego. Which fuse to tap into switched power and best location to tap in the o2 bung.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You will want a constant power source (like power to your dash clock would work). The best location for the sensor goes on the downpipe after the turbo, but before the cat (in your case you don't have a cat on the downpipe, so as far down the downpipe as the wiring will reach, but before the midpipe). The invidia should have a pre-welded bung for the 02 sensor already.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    On the GD cars, the clock pod has the easiest wiring to access. In general, though, I recommend the power outlet wiring, as that can handle higher loads than other dash wiring.
    Tap the bung in the bellmouth, if possible. My Cobb downpipe had a convenient pre-tapped bung right on top.
    2007 Outback 3.0R wagon
    Jun 2012
    This invidia pipe doesnt come with 2 taps. So should i tap into the wiring of the 12v power or fuse?
    2013 SWP WRX Sedan
    Hillside, NJ
    Nov 2012
    http://www.invidia-usa.com/Products.aspx?ProductID=261
    is that not the downpipe you have?
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Take car to an exhaust shop. Have them weld a bung on (test fit it first so you know where to have them doit). You don't want constant power for the AEM. Just a switched power source and a ground. Buy one fuse tap so you don't have to splice any wires.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Jun 2012
    Its the invidia downpipe with only 1 o2 bung which is occupied by my regular o2 sensor.
    2013 SWP WRX Sedan
    Hillside, NJ
    Nov 2012
    Quote Originally Posted by anpato View Post
    Gotcha. Yup, anywhere down stream of the turbo will work, but they put the sensor (invidia I mean) puts it on the bellmouth like in that picture. I personally have mine far enough down to be out of the engine bay. The closer to the turbo, the more heat, the shorter the life of the sensor.
    Jul 2012
    Rocky Top
    Fuse tap and AEM recommends plugging into the ignition or something with a decent amount of power.
    Palmyra, NJ
    You have to ADD another bung aside from the stock o2 bung on that downpipe.
    Jun 2012
    Anyone know where the fuse for the cigarrete lighter is?
    2013 SWP WRX Sedan
    Hillside, NJ
    Mar 2012
    Palm Beach, FL
    Look at the back of your fuse panel. I think I used the windows for switched power on mine and its running the Defi boost gauge and my AEM
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    Jun 2012
    Thanks Maus, my gauge will be here on Saturday, will post pics when its installed. Thanks for the help fella's.
    2013 SWP WRX Sedan
    Hillside, NJ
    Registered User S20002STI's Avatar
    Garden City, KS
    I plan on getting the AEM UEGO and having the bung welded into the OEM downpipe on my 2014. Is it okay to remove the heatshield and then leave it off? Is it easy to remove the heatshield and leave the pipe on the car?
    Nov 2012
    Quote Originally Posted by S20002STI View Post
    I didn't care about making mine look pretty as I knew I would be replacing my stock downpipe eventually (which I did), so I just took my DP off and cut a small square out of the downpipe heatshield and then welded a bung into the pipe as pictured. You will want to take the DP off the car as it will be much easier to work on.
