2006 WRX Gauge Cluster in a 2003 WRX?
Results 1 to 12 of 12
This is a discussion on 2006 WRX Gauge Cluster in a 2003 WRX? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; The gauge cluster in my 2003 WRX is looking a little rough, and I came across a 2006 WRX gauge ...
    Registered User SubyWill's Avatar
    Jun 2008
    Orlando, FL
    The gauge cluster in my 2003 WRX is looking a little rough, and I came across a 2006 WRX gauge cluster for a really good price. I have ProSport gauges in my car now, and they're green, so I kind of want to stick with the green theme. I was wondering if this would be a plug and play thing, or would it be really difficult or even impossible? And how would I be able to get the outside temperature to work? If someone could help me out, I would really appreciate it. Thanks!
    2003 WRB Stage 2+
    Bugeye Mafia Member # 191
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    It won't be easy. There are significant wiring harness differences between the 02-04 cars and the later years. Impossible? No. Very unfun? Yes.
    There are some writeups on NASIOC about how to do it, but I've got a better option: I have a 2003 WRX cluster in a box in the garage I'd be happy to sell you. It's in 100% working order, I just swapped it out for an STI cluster.
    If you're interested, PM me.
    2007 Outback 3.0R wagon
    Jun 2008
    Orlando, FL
    Quote Originally Posted by Rambo View Post
    Thanks for the offer! But I kind of want a newer WRX gauge cluster for the red needles and greener lights, they would match my prosport gauges a lot better. But, if I find a 04 WRX gauge cluster, it would basically be plug and play? As opposed to the 05+ ones?
    2003 WRB Stage 2+
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    You'd almost be better off if you can find an '05 STi cluster. I transplanted that into my 2002 WRX with no issues. Seems like there's one or two wires that have to be accounted for, or something. (been a long time)
    It's much prettier than the '02 cluster..the red gauges, etc.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Oct 2010
    Portland, OR
    Are you sure it was an '05 cluster, Ray? I had an '04 STI cluster, and I just had to clip 2 wires to keep from blowing the stereo circuit. The outside temp gauge wouldn't work, and the rear diff overheat warning was on, but there were fixes for those I just never got around to.
    I seem to remember the '05+ clusters were exponentially harder to deal with, but maybe not.
    I remember seeing the writeups on nasioc and scoobymods.
    Oct 2002
    The Old Folks Home
    Oops, I think you're right. Must have been an '04. Senior moment.
    --Ray
    Oct 2010
    Portland, OR
    Ok, here's the thread on how to put an 05+ STI cluster into a pre-2005 car:
    05 STi cluster into any Pre-05 WRX
    As you can see, it's doable, but kludgy at best, and a bunch of functions won't work properly.
    Here's a writeup on how to get a 2004 STI cluster into an 02-03 WRX:
    2002-2003 Gauge Cluster Swap from STI - NASIOC
    With this, every single gauge function will work with enough hacking, but I drove it for a year with the diff light error and the false outdoor temp readings. Those were minor annoyances, but at least the selectable shift light/buzzer worked fine.
    Sorry this doesn't directly answer your question, OP, but it seems like Subaru changed their harness protocol in 2005. It's up to you to decide how much hacking you want to do, but be aware the you MUST correct the odometer reading to match your real mileage. On Subarus, the mileage reading is stored in non-volatile memory on the cluster itself, so you'll need to hire a service to correct it. I got mine done at Tacoma Speedometer for about $100 including shipping. Just give them a call, and they'll walk you through the process. They update the VIN number records to say the car's odometer was replaced and corrected, so there's no potential for fraud. I never had an issue with vehicle registration after the swap, since the mileage was accurate, and the modification was officially documented.
    Oct 2002
    The Old Folks Home
    I'm still driving around with the diff light and wrong temp gauge. I have the attention span of a 5-year-old, sometimes.
    --Ray
    Jun 2008
    Orlando, FL
    What do you guys think about a 2004 WRX gauge cluster? Would it be a simple swap? I just want red needles with the green backlight
    2003 WRB Stage 2+
    Oct 2010
    Portland, OR
    Quote Originally Posted by SubyWill View Post
    Yup, that should be just like the 2004 STI cluster swap.
    Jun 2008
    Orlando, FL
    So I could just follow the same instructions to install? Thanks for the help, I appreciate it!
    2003 WRB Stage 2+
    Registered User SlimJim8804's Avatar
    Aug 2010
    Is it "looking rough" because the cluster lens is all swirled up?
    If so, just replace that and voila, new looking gauge cluster.
