interior rattle
Results 1 to 11 of 11
This is a discussion on interior rattle within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; so iv found out my subi is a rattle box. while the car is worming up in the morning it ...
    Registered User Cardwell88's Avatar
    May 2013
    Houston tx
    interior rattle
    so iv found out my subi is a rattle box. while the car is worming up in the morning it rattles from somewhere in front of the clock, cursing about 40mph it rattles from somewhere in the back. anyone know a good easy way to shut it up other than turning up the radio? if not oh well.....still love the car.
    2013 hatch
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    My car doesn't worm or curse above 40 mph but there are fixes. If its from the back it is most likely the privacy cover in the hatch. I applied some weatherstripping. Havent had my dash rattle. Yet!
    I did some sound deadening & now with the sub blaring at full bass,not a squeak out of the interior.
    Check out this thread 2011 Hatch Rattle
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Get used to the fact that you paid 30k for a piece of **** that's a blast to drive, because it performs well.
    Solid motor mounts and transmission mount should... change... your rattle situation.
  5. #4
    Aug 2012
    Tucson, AZ
    you put Teflon tape or any non-woven tape around the pillars clips
  6. #5
    Registered User W_R_XTC's Avatar
    May 2012
    brunswick ohio
    foam tape. lots of foam tape.
  7. #6
    May 2013
    Houston tx
    yeah i started knocking on stuff and it turns out to be the panel on the hatch. it seems to be only held on by 2 or 3 little clips. ill try and fix it with foam tape this weekend, hopefully that fixes it.
  8. #7
    Oct 2013
    Quote Originally Posted by Cardwell88 View Post
    My dash rattles around 60 MPH, did you ever find a fix for this?
  9. #8
    Sep 2008
    I had a similar sounding rattle in front of the clock at higher speeds. Turns out it was on the exterior plastic piece at the bottom of the windshield that sits below the windshield wipers.
  10. #9
    Oct 2013
    Quote Originally Posted by Schlanseay View Post
    Yeah I could see how it could make some noise, did you just put some foam under it?
    What was your remedy?
    I have already put weatherstripping around my plates to avoid scratching the paint and rattling. I could see using thin weather stripping for the front.
  11. #10
    Sep 2008
    Exactly, I used some small strips of stripping, not solid all the way across though.
    Sent from my iPhone using Tapatalk - now Free
  12. #11
    Oct 2013
    Cool, I will let you know how it works out.
