Boost Gauge installation?
Results 1 to 7 of 7
This is a discussion on Boost Gauge installation? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have a 2009 WRX and i am planning on buying a prosport halo boost gauge. I have been reading ...
    Jul 2012
    Yuma AZ
    I have a 2009 WRX and i am planning on buying a prosport halo boost gauge. I have been reading all about the installation process but frankly i cant find any decent videos or pictures with the explanations. My main questions are, does the vacuum line T into the line before the bypass valve? With the supplied harness will i be able to wire the gauge straight to my stock gauges? And lastly, when zeroing out the gauge, should the gauge read zero when at idle?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You want the T connected to an engine manifold pressure source that is downstream from the throttle body. At idle the gauge will read negative (vacuum). You will need to wire it into a constant power source (such as your clock or you could connect directly to your battery).
    Jul 2012
    Yuma AZ
    alright thats whats what i thought! at what point should the gauge read zero? Im obviously new to gauges and want to know all i can before installing it
  5. #4
    Nov 2012
    The gauge would read zero somewhere in between the time you are not running boost and when you are running boost
  6. #5
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    It reads zero when ignition is on and engine not running. At that point intake press is same as atmospheric , i.e. zero as far as vacuum/vs charge from turbo. Until the running engine comes into boost there will be vacuum, just like any N/A engine, during boost there is actually air being actively blown into the engine, that's where the more fuel is needed and more power is generated. And that's also where head gaskets, pistons, rods, etc go bye-bye if things are not made right.
  7. #6
    Registered User WRX-Man's Avatar
    Jan 2012
    OCD has one of the best DIY boost gauge install threads. With great pictures. Shoudl help you out.
    SMY and Defi Gauges install - great pics if you want them! - NASIOC
  8. #7
    Jul 2012
    Yuma AZ
    Thanks everyone! Very helpful!! Cant wait to get back to the states and install!
