Yes. That is fine, I did the same this last week until my a pillar gauge pod came in.
This is a discussion on boost gauge install questions within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hello Everyone, So i bought a Prosport 52mm Premium gauge last week and i had a question or two: First ...
Hello Everyone,
First Ill show how i ran the boost lines with a few pics i took. (me and my friend cut the t connector down on both sides a bit with a pair of dykes)
Now i ran in line hose through the firewall where i have the boost sender up near the wiring harnesses off to the right of the dead pedal. (temporary)
Heres the big question. I ran into some doubts in regards to mounting the gauge as well as if im going to wire it to the fuse box or elsewhere, So until all doubts are removed about this im going to hold off finishing the installation. Now will this be ok if i have the boost line setup all the way to the boost sender but not have the gauge itself wired up? Also i would greatly appreciate and input or advice as to wiring and mounting of the gauge. Thanks in advance
2011 SWP Hatch boost gauge install
Here's the link I used to help me install mine, it help alot.
