Results 1 to 10 of 10
This is a discussion on .►► Real THERMAL IMAGING Night Vision Custom Install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I did this on my g35, I'm doing it on my WRX next. Got a FLIR thermal imaging night vision ...
    Mar 2013
    I did this on my g35, I'm doing it on my WRX next. Got a FLIR thermal imaging night vision camera for a 99-03 Cadillac Deville, install a 5" monitor above my CD player and install the camera behind the grill.
    Cadillac camera is pretty expensive, usually sells for $800-1200 on ebay but I found one locally for $300. Be careful when buying the camera, there are 2 versions. 2nd gen version is smaller and better. 1st gen version had a bad seal and water would get in it and it would rust out all the electronics inside (don't buy). I've had four 2nd gen version cameras and they all worked fine.
    Here is a video of the camera working @: www.007licenseplate.com/nightvision/
    How it looks in the Cady
    full car back exhaust header head heads straight ecu ecm intake rims wheels bearing manifold cam cams cd cold air suspension springs lower coilover racing speed carbon fiber hood shifter shift short seats tires muffler seat twin turbo supercharger kit hid blower awe fwd lsd intercooler roll cage jdm vtec swap boost psi max awd rwd rwd trans
    Registered User nopistons93's Avatar
    Sep 2011
    Norfolk
    Pretty cool, could you wire it into an aftermarket head unit? What is the output of the camera in, hardware wise?
    Oct 2005
    Late Devonian
    I want that.
    Mar 2013
    You can connect it to any tv/head unit that has a typical yellow RCA wire input. On the camera there are 6 pins, 2 not used, 2 power, and 2 for picture. Very easy hooked up. I've never had any problems connect the camera to and TV with RCA video and the 5" LCD I have it connected to in my car is a cheap $25 ebay 5" 320x240 lcd. Camera's resolution is 320x240 so I didn't have any need to get a higher resolution lcd.
    ClubWRX.net Vendor rexxx0486's Avatar
    Jan 2007
    North NJ
    That is bad ass
    -Clayton, Your official CLUBWRX Subaru Dealer!
    CLUBWRX New car buying program SAVE HUGE on new Subarus:
    http://www.clubwrx.net/forums/tri-st...ubwrx-net.html
    Ask a Subaru Dealer thread:
    http://www.clubwrx.net/forums/car-pu...ru-dealer.html
    FREE 3rd party vehicle inspections:
    http://www.clubwrx.net/forums/tri-st...spections.html
    Mar 2013
    Anyone have any questions or comments? PS i have the cadillac camera pinout if anyone wants it for their set up just PM me
    Aug 2012
    Bristol, CT
    wanna do it for me?
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    I feel like this would just distract me. I haven't had an issue seeing deer or people with my regular headlights.
    Oct 2005
    Late Devonian
    The real advantage is being able to see further peripherally at distance. The deer I have had trouble with all jumped out from the side - the ones already in the road are usually easy enough to avoid. I do question whether the mounting position in the front of the dash would be noticeable enough though, yet I'm confident I wouldn't want it where the Caddy illustrates it unless that is a real head's up display and you can easily see what is through it. Even then it looks too big.
    Mar 2013
    Can be a bit distracting I'm not gonna lie. Sometimes I cant stop glancing over at it as I drive but since it is a front facing camera you can still see where you're going lol
