Windows do not roll up at the same speed - please check - Page 2
View Poll Results: Do your windows go up the same speed? If not, which one is slower?
Voters
48. You may not vote on this poll
  • both front windows roll up the same speed
    10 20.83%
  • both rear windows roll up the same speed
    9 18.75%
  • one of the front windows is slower than the other
    36 75.00%
  • one of the rear windows is slower than the other
    10 20.83%
Multiple Choice Poll.
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 56
This is a discussion on Windows do not roll up at the same speed - please check within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally Posted by marx When you operate more than one window at the same time you are drawing more load ...
    Feb 2013
    Quote Originally Posted by marx View Post
    When you operate more than one window at the same time you are drawing more load so you will have a drop in voltage which inturn will slow the windows down. If the load goes up (amps) the voltage drops. Its not getting to the point of blowing a fuse but that's what I think is happening. Just a thought.
    In theory though, if they are the same motors and are switched at the same time, they should close at the same time too, right?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I had the same problem in my 2006 WRX when it was new.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Oct 2012
    What happens if you roll them up/down independently? Is one still faster than the other? If they're the same speed in that situation, I second the it could be dirty observation.
    For what its worth I think mine (in a 2012) are about the same speed.
  6. #19
    Registered User itiswhatitisnt's Avatar
    Nov 2012
    Japan
    I noticed the same issue as mine... I have a 2013 wrx sedan. it does exactly what you described. Next oil change I will address the issue to the service/mechanic.
  7. #20
    Registered User marx's Avatar
    Jan 2013
    Maine
    That's a good question. I think they are the same motors but they operate off of the same relay. They will use less power coming down than going uo so the draw wont be as much.
  8. #21
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Wow, this is the epitome of a "first world problem".
    I've noticed the "slower multiple windows" for the entire time that I've had 2002 models. It's just more amps being pulled by the motors, and there isn't but so much to go around. I've never paid attention to differences in individual rates. If it's truly a nuisance to you, take it to the dealer and see if they'd be willing to crack open the window assembly and make sure there's no extra drag in there. It would SEEM like the motors themselves would be pretty uniform..though who knows.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  9. #22
    May 2010
    Pittsburgh, PA
    My rear windows nearly stop if I try to put more than one up at a time. It's awful.
    I know it's not a first world problem, but when it takes about 20 seconds (no joke) to put a rear window up... it gets old pretty fast.
    2011 STi Build Log
  10. #23
    Oct 2002
    The Old Folks Home
    A "first world problem" means that it's trivial in the big picture...meaning if you compare it to people without clean water, etc, in 3rd world countries, well, you get it. So slow power windows actually IS a first world problem.
    Yeah, 20 seconds would certainly drag out. I don't really make all 4 go up and down that often..I'll try mine some time to see if it's the same situation.
    --Ray
  11. #24
    May 2010
    Pittsburgh, PA
    Touche on the first world problem.
    I dunno if they are gonna keep working or not. They've gotten drastically slower over the past year at least. Would be nice if they failed before my warranty is up next year, but we all know how that works out.
    2011 STi Build Log
  12. #25
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    One of my rear windows did this. It was terribly slow. I removed the door card and re-greased the rail/guide with wd-40. Problem 100% solved.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  13. #26
    Oct 2002
    The Old Folks Home
    Wow, you should do a tutorial.
    Lokey Shows You How to Grease Your Rail
    --Ray
  14. #27
    Palmyra, NJ
    Quote Originally Posted by Betlog View Post
    I know it might not be a big deal but this is my first Subaru. From my recollection, all my previous cars' windows rolled up the same speed (Acura, Honda, Toyota). So to me, it feels weird. I just want to know if this is normal or not.
    Haha I know what you mean. Mine do it to on my 05 STI. They did it since brand new on my 07 STI when I had it...the window motors on these cars have never been particularly powerful. They go even slower if the car is not fully turned on (only in accessory/battery mode) and if you do any combination of more than one at the same time.
  15. #28
    Jan 2011
    Crofton, MD
    LOL.
    Step 1 - Remove door card.
    Step 2 - Peel pack plastic sheet covering holes.
    Step 3 - Locate guide/rail.
    Step 4 - Spray it with wd-40.
    Step 5 - Put your door back together.
    2008 - 2012 WRX inner door panel removal. - YouTube
    Greg
    Build Thread
  16. #29
    Dec 2011
    Pottstown PA
    hahaha my 2002 works fine take it to the dealer if it takes 20 seconds. aint nobody got time for that. also your poll doesnt meet clubdub rules..... no ( . Y . ) option
    Marky Mark
    My bugeye build
    MinoskePhotography
  17. #30
    Jan 2012
    Philly Area
    Quote Originally Posted by Ruh Roh View Post
    no ( . Y . ) option
    8-Bit Pornography! Ban!
    - Will
