Is there anything bad that can happen if there is indeed a leak? I don't want to drive the car until its resolved if it could be detrimental
This is a discussion on boost gauge reading? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; It only has 1200 miles on it and was broken in properly....
2013 SWP WRX 5-Door
2005 OBP WRX 4-Door SOLD
2013 SWP WRX 5-Door
A vacuum leak will cause the car to run lean at idleOriginally Posted by rurso01
Which only effects mpg and what not right? Nothing mechanical?
2013 SWP WRX 5-Door
It's something you want to fix ASAPOriginally Posted by rurso01
- William
I was doing some research on others who have a boost gauge operating correctly with PSI but idle is at 0 and some people mentioned the hose could be pinched? Could this be a possibility? I get that the vacuum could be leaking and while that is the worst case scenario, is it the most likely considering it has been driven 3 times since its install from the dealership?
Also EJ257, are you from the area?! I saw you mentioned Gaithersburg.
2013 SWP WRX 5-Door
Sorry one more question.. how should I approach talking to the dealer about this? Not normally put into this type of situation. I am thinking of taking it up with the service manager since the tech who worked on it was quite douchey and sorta rude to me during the 15 second convo I had with him about placement of the gauge.
2013 SWP WRX 5-Door
Didn't realize it was so recently installed.Originally Posted by rurso01
NoOriginally Posted by rurso01
Just explain the symptoms you're having. Don't guess the problem.Originally Posted by rurso01
Does it being so recently installed make you second guess the whole vacuum leak idea?
2013 SWP WRX 5-Door
I'm not sure. But you're noticing a problem with a recent install. Call yesterday to explain there may be a possible issue with services rendered (depending on how long it's been, you could get fixed free).Originally Posted by rurso01
It was installed on Thursday so its definitely related to the install. I am going to take a picture and upload it in a few minutes. I don't know if they t'd it in the best place. They sliced the mesh material hose. When I have looked at other install pics, people have used a different hose to install on. Uploading shortly...
2013 SWP WRX 5-Door
2013 SWP WRX 5-Door
2013 SWP WRX 5-Door
2013 SWP WRX 5-Door
