Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
This is a discussion on LED + One Touch Blinkers within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; First thread here... Picked up my 2013 WRX a couple weeks ago.. It's been in the garage since getting mods ...
    Registered User chutoyy's Avatar
    Sep 2012
    Sacramento/Orange County
    First thread here... Picked up my 2013 WRX a couple weeks ago.. It's been in the garage since getting mods put on it... I'll get a build thread going sometime...
    Anyway, thought I'd share some information- I found this website (WebElectric Products - Sequential Turn Signals, Sequential Taillights, Sequential Tail Lights, Dynamite Stick Sequential, Pulsing Brake Light Pulser Flasher, One Touch Convertible Top, Dynamite Stick, One Touch Turn Signals, Daytime Running Lights, L) when looking for the one touch turn signals for my previous car. Found out that they do have a OTTS flasher that also rids of hyper blink when using LED turn signals for the WRX.
    It's expensive, but it's a cleaner install than having resistors wired to all 4 corners and the convenience function... Easy install as well- a direct replacement (if there's enough interest, I'll throw up a DIY).
    Love it, hate it, call me lazy, but at least I signal.
    Here's a pic of the OEM flasher and the WebElectric flasher (right):
    Here's a video of it in action:
    Registered User Stawgn10's Avatar
    Apr 2010
    Colorado Springs
    I like the one touch blinker, not that it's wearing me out or anything holding the blinker down while I'm passing.
    2010 WRB WRX wagon
    Apr 2010
    Colorado Springs
    Which one did you use for the one touch blinker? Is it the one shown in the picture -4650? 8 pin?
    2010 WRB WRX wagon
    Nov 2012
    Eastern PA
    Re: LED + One Touch Blinkers
    Do you also have LED bulbs for your signals? I'd like to see how they look from the outside. Interested in doing LED signals, just worried about it looking too 'aftermarket'.
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    I'm interested. I've never seen this before. Let's see the DIY. Thanks.
    Sep 2012
    Quote Originally Posted by Stawgn10 View Post
    oops, left that info out... It's the one that says Toyota/Lexus with the picture of a Prius...
    Quote Originally Posted by raceoholic330 View Post
    Yes I do. It all depends on which bulbs you buy, but LEDs are usually dimmer than regular orange bulbs.
    These are both LEDs.. one is a cree LED and the other is one of those regular easy to find ones...
    Quote Originally Posted by jgardiner View Post
    Hmm.. Maybe I'll throw one up with a LED demo vid thing...
    Apr 2010
    Colorado Springs
    Quote Originally Posted by chutoyy View Post
    Thanks,
    I'm just lazy enough to order that.
    2010 WRB WRX wagon
    Nov 2012
    Eastern PA
    That would be awesome. I would love to see how they look flashing from 20' away or so.
    Sep 2012
    I'll see what I can do... but my lights are no longer stock.. this is my recent project...
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    That does seam rather overpriced.....$50 is a bit much.
    Just FYI, you do not need to wire resisters into 4 corners...there are LED blinker modules available for all years for like $20 that fi the blink rate for LED bulbs.....those are not 'one touch', but that is no real big loss IMO.
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    Sep 2012
    Ah, that's true. Forgot about those other modules...
    Quote Originally Posted by DemonWRX View Post
    Aug 2012
    Where is the flash module located in the car? I just got my OTS flasher module in the mail.
    Sep 2012
    It's at the very top of the relay box... which is right next to the fuse box under the dash on the driver's side.
    You'll have to remove the side dash panel, two screws that hold the bottom kick panel and remove the panel (under the steering wheel).
    The relay box can unclip (slide it towards you after releasing the clips) from the fuse panel making it easier to pop the relay off (also a slide clip).
    Quote Originally Posted by lftjeep View Post
    Aug 2012
    How long did it take you to install it?
    Sep 2012
    Took me about 15 minutes...
