Page 1 of 3 123 LastLast
Results 1 to 15 of 33
This is a discussion on 2013 wrx kartboy short shifter install, but scared to try the bushings. :-( within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just bought the kartboy short shifter for my 13 wrx. I have no worries on the that part of the ...
    Registered User thegamer1587's Avatar
    Oct 2012
    Western Pa
    Just bought the kartboy short shifter for my 13 wrx. I have no worries on the that part of the install, but i'm scared to death to attempt the bushings. So scared in fact, I didnt even buy them.......
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Scared? Of what? Unless you are claustrophobic there really is nothing to be scared about.(install is from under the car). If you know how to manipulate a wrench & tighten a bolt with your hand,it can be installed.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Oct 2012
    Western Pa
    The install just seems like its extra difficult.
    Aug 2010
    Yonkers/NYC
    If you have access to a lift it is actually quite simple. Otherwise raise the car & take off of or move the heat shield out of the way(4 bolts)
    The rear bushings involve removing 2 bolts & installing the new bushing. The only issue you may run into is that it is tough to thread the new bolts.
    For the front,its as simple as taking off one bolt,taking the stock bushing off & installing the new bushing.
    Where are you located? Maybe someone from your local forum would be willing to help you with the install for some compensation.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    The bushings are the most noticeable (shift feel-wise) part of the install.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Oct 2012
    Western Pa
    Im from south west pa. Is there any reason I couldn't use a set of ramps rather than using a jack and jack stands? I have a decent floor jack and a set of ramps, but no floor jacks.
    Oct 2012
    Western Pa
    Whoops! Meant to say....but no jack stands!
    Apr 2004
    Southeastern PA
    Did mine on ramps. Chock the rear wheels if you are that worried.
    Mods & Pics
    Aug 2010
    Yonkers/NYC
    I'd prefer a set of ramps if you are thin enough to get under the front of the car with just the front raised. For me, I drive the car up a set of ramps,jack up the rear & lower the rear on jack stands.
    But please do not think about jacking the rear & sliding under the car. A set of jack stands can be bought for as less as $15.99 from Harbor Freight.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Oct 2012
    Western Pa
    Ok, Thanks for the advice fellas! Dont know if I would have survived any of my mod installs if it wasnt for these forums. So far I did rally armour flaps ( very scary to pop the ground effects out of place on a brand new car!), Footwell illumination kit, and the nameless axleback muffler delete.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by rage-wrx View Post
    As a Sasquatch I am far from thin enough, but did very well without the rear raised.
    Mods & Pics
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    OP....where in S/W PA?
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    Oct 2012
    Western Pa
    Somerset PA, about 15 minutes away from where flight 93 went down.
    Registered User Undone10's Avatar
    Jul 2008
    Philly
    Maybe I should install new bushings. I have a 11 and my shifts are so rough. Could my old bushings be bad already?
    Sorry about the hijacking.
    - 2011 WRB STI
    Cobb stage 2 tune ~ Invidia turbo back exhaust
    Oct 2011
    Santa Ana, CA
    Re: 2013 wrx kartboy short shifter install, but scared to try the bushings. :-(
    Define "rough". Being AWD with a finicky clutch can make shifting jerky unless the revs are JUST right when letting out the clutch.
    Posted from a fone.
