B pillars, you loosen the bolt behind the cover, pull off the seatbelt cover by hand which will expose the bolt holding it in, remove that, then it should come out.
C pillars, loosen bolt behind SRS cover, remove push clips, the bolts under the seat do have to come out so you can fish out the seatbelts, theres also a few screws in the trunk area.
LinkBack URL
About LinkBacks
Got my a pillars done today as the first step. Now just need to do the b and c pillars. How do you get them off? How do you get the front seat belt covers off? And with the c pillars do you have to unbolt the seatbelt down at the bottom of the back seat and feed it trough the plastic pillar piece?
