Cluster Dimmer
Results 1 to 3 of 3
This is a discussion on Cluster Dimmer within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was installing the Lamco Boost Gauge today and somehow blew the fuse #12 (illumination) and ever since then I ...
    Aug 2012
    A, A
    Cluster Dimmer
    I was installing the Lamco Boost Gauge today and somehow blew the fuse #12 (illumination) and ever since then I cant get the dimmer to work. It is stuck on the lowest setting and is barely visable. I checked the other fuses and are okay. Any thoughts?
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Check your wiring. The fuse blew for a reason, so trace all your leads. I suppose it might be possible to burn up the dimmer pot, but I doubt that.
    2007 Outback 3.0R wagon
    Aug 2012
    A, A
    I pulled the under of the steering column and didn't notice anything strange. The Boost gauge isn't hooked up electrically anymore so that couldnt be the problem could it? (although the wire is still hooked up to the back of the radio deck)
